Another Trailer.........Flame away!
发表于 2021-8-31 22:54:22 | 显示全部楼层 |阅读模式
Getting the trailer assembled........Not much welding on the trailer yet.  Starting to cut all the un-needed crap off the truck.   Yes, THAT IS a 150 Ton Grove.........biggest rough terrain crane in the world!! Attached Images6 Miller Big Blue 600 Air Paks2 Miller 400D6 Lincoln LN-25's4 Miller Xtreme 12VS2 Miller Dimension 812 4 Climax BW-3000Z bore welders Hypertherm 65 and 85Bug-O Track BugPair of Welpers
Reply:I remember my first trailer build [Account Abandoned 8/8/16 Please Do Not Attempt Contact Or Expect A Reply]. See you on YouTube! -ChuckE2009
Reply:Reminds me of time spent at the mine around the tow rig. Looks good.
Reply:Are you sure that will be strong enough?
Reply:Originally Posted by ExpatWelderGetting the trailer assembled........Not much welding on the trailer yet.  Starting to cut all the un-needed crap off the truck.   Yes, THAT IS a 150 Ton Grove.........biggest rough terrain crane in the world!!
Reply:The Liebherr is not classified as RT6 Miller Big Blue 600 Air Paks2 Miller 400D6 Lincoln LN-25's4 Miller Xtreme 12VS2 Miller Dimension 812 4 Climax BW-3000Z bore welders Hypertherm 65 and 85Bug-O Track BugPair of Welpers
Reply:Originally Posted by BEYTILLHere comes the flam'n Not even close......Liebherr makes a 400 ton and I've worked with 250's many times.
Reply:I need a truck like that for when I get stuck in dallas traffic.  Haha
Reply:That's one of those bolt together HF trailers...  .No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:Expat, You make Tim Taylor proud.UGH UGH UGH UGH!There are no problems. There are only solutions. It's your duty to determine the right one.Hobart Handler 210Airco 225 Amp MSM Stinger
Reply:Get are real welder and build a properly sized trailer.  Get a real truck as well while your at it. Wtf you want to get people hurt. Jeez!
Reply:Originally Posted by kaldGet are real welder and build a properly sized trailer.  Get a real truck as well while your at it. Wtf you want to get people hurt. Jeez!
Reply:Was that a Harbor Freight 90 amp stick machine and some 6013 he was using
Reply:Originally Posted by vwguy3Was that a Harbor Freight 90 amp stick machine and some 6013 he was using
Reply:Originally Posted by ExpatWelderThe truck IS a piece of ****e!!!  It has 70,000 hrs on it and I have repaired cracks in EVERY single place that they EVER crack in.........and some places I have never seen crack on a 777.................then we replaced the entire power train..........so basically its STILL a piece of ****E!
Reply:Originally Posted by jamesyarbroughAs long as it will clear a honda civic that's all I need. How bout $500 for the truck?
Reply:I have worked with a lot of Grove hydraulic rough terrain's, mostly 45T. I don't know if it is the pictures or view point but I think the outriggers and jacks seemed to be about the same size, thought a 150T would be a lot bigger, just surprised on the out riggers. Could not find that trailer in the HF catalog, LOL."Si Vis Pacem Para Bellum"Lincoln Idealarc 250 AC/DCMillermatic 251   Syncrowave 300   30A spoolgunLincoln MP210Hypertherm 45(2) LN 25(2) Lincoln Weldanpower 225 CV(4) SA200   1 short hood    SA250    SAM 400
Reply:you are correct on the grove. the 400 ton liebherr is an AT (all-terrain able to be driven at highway speeds)
Reply:Originally Posted by kolotI have worked with a lot of Grove hydraulic rough terrain's, mostly 45T. I don't know if it is the pictures or view point but I think the outriggers and jacks seemed to be about the same size, thought a 150T would be a lot bigger, just surprised on the out riggers. Could not find that trailer in the HF catalog, LOL.
Reply:New Machines!! Attached Images6 Miller Big Blue 600 Air Paks2 Miller 400D6 Lincoln LN-25's4 Miller Xtreme 12VS2 Miller Dimension 812 4 Climax BW-3000Z bore welders Hypertherm 65 and 85Bug-O Track BugPair of Welpers
Reply:Originally Posted by ExpatWelderNew Machines!!
Reply:You need more red machines,us bridge builders only use them! !!
Reply:Originally Posted by PavinsteelmanYou need more red machines,us bridge builders only use them! !!
Reply:Run a few RT35's but nothing like that thingNice welding porn You get all the fun toysBacked my CATMA over your CARMA oops clusmy me  What would SATAN do ?? Miller Trailblazer 302 AirPakMiller Digital Elite  Optrel Welding HatArcair K4000Suitcase 12RC / 12 VSHypertherm PM-45Rage 3 sawRusty old Truck
Reply:Originally Posted by ExpatWelderI have a BOATLOAD of red machines...............can't keep the bloody things running!  Only getting 5000 hours on the engines..........(Air Vantage 500's)..........the VMAC compressors are $HIT............I really like my LN25's though......and my Idealarc 600'sOriginally Posted by BD1Maybe paint the red ones BLUE   May help them.
Reply:Originally Posted by ExpatWelderI have spent A LOT of time on this crane and every time I see it from a distance, or in a picture I always think to myself......"this thing just doesn't look that BIG"............but once you get up close to it...................it's a FREAKING MONSTER!!!!!!!Check the DIY section of HF for the trailer kit...........you know the section where they sell the plans for the homebuilt trailers????  This job is big enough that I will probably need to use TWO of those little 110V MIG machines....................May have to anyway, cause the power is 230,,,,,,,,so if I hook 2 of the 110V machines up to the same line, it should pull 220 or so right???
Reply:How are your 12 VS to the LN-25?  We found the new 25 are built cheeper to compete with Miller &.Esab?
Reply:Personally i think the old style LN-25 is the best Vs wire feeder ever made.    better than the LN-25 pro, 8VS, 12VS,  even the hobart hefty.Vantage 500's LN-25's, VI-400's, cobramatics, Miller migs, synch 350 LX, Powcon inverters, XMT's, 250 Ton Acurrpress 12' brake, 1/4" 10' Atlantic shear,Koikie plasma table W/ esab plasmas. marvel & hyd-mech saws, pirrana & metal muncher punches.
Reply:Originally Posted by PavinsteelmanHow are your 12 VS to the LN-25?  We found the new 25 are built cheeper to compete with Miller &.Esab?
Reply:Originally Posted by soutthpawNa, you need to paint them black and we will send you some Harbor Freight Decals for them !   then you can get a 2 year replacement warranty for $10
Reply:Originally Posted by BiggerairHow about the compressor in the Airpaks ? I have been looking at them for my next machine but was curious about the compressor side.
Reply:Few more pics Attached Images6 Miller Big Blue 600 Air Paks2 Miller 400D6 Lincoln LN-25's4 Miller Xtreme 12VS2 Miller Dimension 812 4 Climax BW-3000Z bore welders Hypertherm 65 and 85Bug-O Track BugPair of Welpers
Reply:..........and some more Attached Images6 Miller Big Blue 600 Air Paks2 Miller 400D6 Lincoln LN-25's4 Miller Xtreme 12VS2 Miller Dimension 812 4 Climax BW-3000Z bore welders Hypertherm 65 and 85Bug-O Track BugPair of Welpers
Reply:Just goes to show, the size of the sand box REALLY does dictate the size of the toys!RogerOld, Tired, and GRUMPYSalesman will call, Batteries not included, Assembly is required, and FREE ADVICE IS WORTH EXACTLY WHAT YOU PAY FOR IT!Dial Arc 250HFThunderbolt 225 AC/DCAssorted A/O torches
GMT+8, 2025-12-29 03:28 , Processed in 0.097140 second(s), 18 queries .
