TA186 welding cart build
发表于 2021-8-31 22:54:21 | 显示全部楼层 |阅读模式
Here are some pictures of the welding cart I built for my Thermal Arc 186.  Hope you enjoy.All Painted up.All together with the welder and cooler on.  Yes, that is a burgundy coolmate 3 you see.
Reply:Neat and tidy. Nicely done.Nice bright garage/workshop ... looks roomy.  What are the dimensions?ESAB Heliarc 252
Reply:Originally Posted by BlauSchuhNeat and tidy. Nicely done.Nice bright garage/workshop ... looks roomy.  What are the dimensions?
Reply:I was just going to comment on the 'shop' floor. Looks awfully clean, nothing like the 'boily' workshops I've been in. Although, most of the work I've been associated with uses the blue sky workshop.
Reply:Nice cart.   Your shop is SHINY !
Reply:Very nice cart and well thought out. What did you use to bend the lead hooks?TOO MANY TOOLS & NO MORE SPACE
Reply:nice cart.  nice lathe too.  I have the same one.
Reply:Originally Posted by Chris T.Very nice cart and well thought out. What did you use to bend the lead hooks?
Reply:WOW, a brand spanking new shop!  No way anything has been done inside it, cause of the sparkly floor.  I would be afraid to walk across it, much less start any projects.  And a Lathe in the background.  NICE.BTW, nice cart.MarkI haven't always been a nurse........Craftsman 12"x36" LatheEnco G-30B MillHobart Handler 175Lincoln WeldandPower 225 AC/DC G-7 CV/CCAdd a Foot Pedal to a Harbor Freight Chicago Electric 165A DC TIG PapaLion's Gate Build
Reply:Originally Posted by MarkBall2WOW, a brand spanking new shop!  No way anything has been done inside it, cause of the sparkly floor.
Reply:Is that an epoxy floor or did you lay something down?I couldn't get away with something laid down, I drop too may sharp objects.MarkI haven't always been a nurse........Craftsman 12"x36" LatheEnco G-30B MillHobart Handler 175Lincoln WeldandPower 225 AC/DC G-7 CV/CCAdd a Foot Pedal to a Harbor Freight Chicago Electric 165A DC TIG PapaLion's Gate Build
Reply:It is epoxy with a urethane clear top coat.  So far seems pretty tough although I did drop my steady rest and took a chunk out of it along with the floor.  Had I found a good deal on it I would have laid some ceramic tile down but I couldn't find any cheap enough at the time.
GMT+8, 2025-12-29 03:30 , Processed in 0.096941 second(s), 18 queries .
