Heavy duty aluminum hinges
发表于 2021-8-31 22:54:21 | 显示全部楼层 |阅读模式
My next project requires two heavy duty Ali hinges.  The hinges need to be bent in order to let the door open flush with the side of the truck body.  The picture below shows the hinges I am looking for.  You can see how the plate is bent to allow it to open as I'd like.  Anyone haven a source of a hinge? Attached Images
Reply:These yet aluminum. Attached Images
Reply:You could make them. Its easier and more cost effective.
Reply:I have no way to bend the eye.
Reply:Maybe here?http://www.hardwaresource.com/hinges...um+Strap+Hinge
Reply:Instead of bending the eye, use tube/pipe and then weld on your strap. That or bore it out of solid stock..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:Thanks jw, they need to be weldable, so no cast.  Somehow I traced that picture to a manufacturer of that body.  I have an email into them saying I need replacements so crossing my fingers they will sell me parts.In the end I might have to do that Doug.
Reply:Originally Posted by DSWInstead of bending the eye, use tube/pipe and then weld on your strap. That or bore it out of solid stock.
Reply:http://www.gpartsinc.com/p-1966-2-tr...FWKCQgodEC4A-AVantage 500's LN-25's, VI-400's, cobramatics, Miller migs, synch 350 LX, Powcon inverters, XMT's, 250 Ton Acurrpress 12' brake, 1/4" 10' Atlantic shear,Koikie plasma table W/ esab plasmas. marvel & hyd-mech saws, pirrana & metal muncher punches.
Reply:Would you look at that.  Thanks man.
GMT+8, 2025-12-29 03:29 , Processed in 0.096750 second(s), 18 queries .
