查看: 2|回复: 0
I was wondering.. turbo miller Bobcat
发表于 2021-8-31 22:54:19 | 显示全部楼层 |阅读模式
I have a few small and large turbos laying around from cars. Some good, some bad.I was wondering if my idea would work...I was thinking of installing a small t28 (stock sr20det) turbo on the exhaust manifold of my bobcat. Have a small dc pump circulating maybe a quart of fluid to keep it lubed, and the turbo coldside inlet/outlet just open to atmosphere.The engine itself wouldn't be turbo'd or mess with afrs or anything, but I would get the turbo whine when the engine revved up from idle. Think it will work for no other reason than to rice my bobcat out? Ha ha..Who knows, maybe use the turbo outlet as a leaf blower or vacuum?I have all the flanges laying around, along with all the pieces necessary to get this to work, maybe shy one or two oil fittings, even have the dc oil pump. Think it would actually spool the turbo enough to get it singing?Miller: 200dx, Bobcat 225, Passport, Powermax 45, Milwaukee: Dry Saw, MagDrill, grinders
Reply:I'm going to just pretend I didn't read this and go to bed...Welding/Fab Pics: www.UtahWeld.com
Reply:There are other forums for that...However, you could theoretically see up to a ~30% increase in HP with roughly the same fuel consumption. That would be something most of us would like to see. Couple that with an intercooler you might even get to about 35%...I break things for a living...
Reply:I put a 6-71 Detroit blower on mine.  That blower whine sounds cool. Last edited by duaneb55; 05-20-2013 at 02:25 AM.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Originally Posted by MikeGyverI'm going to just pretend I didn't read this and go to bed...
Reply:Keep it simple and do a suck thru so you don't have to deal with modulating fuel pressure as boost increases.What the heck - might as well put a 10hp spray on it too! MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Hmm, what would that be? .005 for nitrous and .002 for fuel? Might as well go for a wet shot! I think I have an adjustable riding rate fpr laying around...Sent from my Galaxy Nexus using Tapatalk 2Miller: 200dx, Bobcat 225, Passport, Powermax 45, Milwaukee: Dry Saw, MagDrill, grinders
Reply:If all you want is the turbo whine, just take a sound clip from youtube and play it on your ipod while you weld?
Reply:If you need any pics, let me know. My Bobcat came from the factory with a turbo. But, I can't really say you can hear the turbo whine, when at full RPM."Where's Stick man????????" - 7A749"SHHHHHH!! I sent him over to snag that MIC-4 while tbone wasn't looking!" - duaneb55"I have bought a few of Tbone's things unlike Stick-Man who helps himself" - TozziWelding"Stick-man"
Reply:Originally Posted by duaneb55I put a 6-71 Detroit blower on mine.  That blower whine sounds cool.
Reply:Photoshop?  Did that with Paint and impressed myself to boot.  What do want for a quick 1 minute cut-n-paste job to get it posted? MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:How much pressure can you build with a turbo?Maybe put a tank on it and have a bobcat airpak
Reply:Did anybody read the original post? He's not talking about turbo'ing an engine... there IS nothing to tune or anything of the sort.Welding/Fab Pics: www.UtahWeld.com
Reply:Yup.  I just figured he wouldn't stop at a whistle blower noise maker once he got started.  Hence my post.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:If he riced it a little maybe it would be able to take corners better.
Reply:Fine, I'll be the one to say it.I think it'd be cool [Account Abandoned 8/8/16 Please Do Not Attempt Contact Or Expect A Reply]. See you on YouTube! -ChuckE2009
Reply:you need one of these
Reply:Now if you turboed and riced out an SA200 this place might become a war zone. Last edited by kald; 05-28-2013 at 12:52 PM.
Reply:Originally Posted by towelyou need one of these
Reply:it is astonishing the number of people that post their stupidity.As for the OP. Why go through the work if you're not going to end up with something useful. Last thing I need with three kids is more noise around.There are no problems. There are only solutions. It's your duty to determine the right one.Hobart Handler 210Airco 225 Amp MSM Stinger
Reply:Originally Posted by duaneb55.........What the heck - might as well put a 10hp spray on it too!
GMT+8, 2025-12-29 03:29 , Processed in 0.100873 second(s), 18 queries .
