3G plate
发表于 2021-8-31 22:54:14 | 显示全部楼层 |阅读模式
I've just started school but been welding for a while and a company came into our class tonight and talked to us about a few possible job openings, they're fabricating skids using 5/32 7018 on 7/16 steel in the flat position and to be eligible for the job I would have to pass a 3G vertical plate test and they're allowing a 1/2'' gap, any tips on how to practice up for this? It's not a make or break job, just something to do while i'm in school. They're not requiring any job experience as long as I can pass the test and the pay is great for a starter job."Firearms stand next in importance to the Constitution itself. They are the American people's Liberty, Teeth, and Keystone under Independence." - George Washington
Reply:Run lots of vertical for practice. Biggest issue I find with students is that they haven't yet learned to read the puddle when they get to vertical. Once they learn and master this vertical is easy. Since you say 1/2" gap, I'm guessing they want you to do a 3/8" test with backing, but you'd need a bit more info from them to know exactly what they want as far as the test. I'd assume they want you  to run 7018 for the test.Here's a pict CEP posted up on the test parameters.  If you prep your coupons this way I believe it would cover what they want. Attached Images.No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:Originally Posted by DSWRun lots of vertical for practice. Biggest issue I find with students is that they haven't yet learned to read the puddle when they get to vertical. Once they learn and master this vertical is easy. Since you say 1/2" gap, I'm guessing they want you to do a 3/8" test with backing, but you'd need a bit more info from them to know exactly what they want as far as the test. I'd assume they want you  to run 7018 for the test.Here's a pict CEP posted up on the test parameters.  If you prep your coupons this way I believe it would cover what they want.
Reply:Originally Posted by Jeromy_EI've just started school but been welding for a while and a company came into our class tonight and talked to us about a few possible job openings
Reply:If you have or know someone who has a compact bender you can bend your coupons with it to see the results of your welds. Attached ImagesDon’t pay any attention to meI’m just a hobbyist!CarlDynasty 300V350-Pro w/pulseSG Spool gun1937 IdealArc-300PowerArc 200ST3 SA-200sVantage 400
Reply:CEP why you so good with vertical  stick welds. Tell me your secrets.
Reply:Who said I was any good? Just like DSW said in post #2, when you learn to read the puddle, and know what it needs, that is 99% of the battle.Don’t pay any attention to meI’m just a hobbyist!CarlDynasty 300V350-Pro w/pulseSG Spool gun1937 IdealArc-300PowerArc 200ST3 SA-200sVantage 400
Reply:Originally Posted by CEPIf you have or know someone who has a compact bender you can bend your coupons with it to see the results of your welds.
Reply:Originally Posted by Jeromy_EI've just started school but been welding for a while and a company came into our class tonight and talked to us about a few possible job openings, they're fabricating skids using 5/32 7018 on 7/16 steel in the flat position and to be eligible for the job I would have to pass a 3G vertical plate test and they're allowing a 1/2'' gap, any tips on how to practice up for this? It's not a make or break job, just something to do while i'm in school. They're not requiring any job experience as long as I can pass the test and the pay is great for a starter job.
Reply:Originally Posted by MinnesotaDaveTry this video:http://www.weldingtipsandtricks.com/...ding-test.htmlAnd the second one:http://www.weldingtipsandtricks.com/...est-part2.htmlHope it helps - good quality from Jody.Dave J.
Reply:If your doing the 3/8 test its pretty easy. Getting comfortable is very important and don't over heat the plate.
GMT+8, 2025-12-29 03:30 , Processed in 0.100370 second(s), 18 queries .
