First time touching a tig!
发表于 2021-8-31 22:54:03 | 显示全部楼层 |阅读模式
So here is my first time tig welding. I know its not the best at all. Let me know what you think. Machine was set up by a welder also, not me. Attached Images
Reply:What settings (amperage, gas, filler size etc) did you use and what size material? The more detailed your information the more the guys can help.Craftsman 90 amp Arc welder
Reply:Only problem to that question is I have no clue. The welder I was with handed me the torch and rod and said  go your turn. So kind of a draw back.
Reply:Originally Posted by cole_977Only problem to that question is I have no clue. The welder I was with handed me the torch and rod and said  go your turn. So kind of a draw back.
Reply:It looks a little undercut, could have used more filler. And that orange haze is from a tungsten dip. Takes quite a bit of practice to get really good at it but they arent bad for afirst time run. Just run about 1000 more of those coupons lol, it really is an art form nearly.
Reply:Sooooo, did ya like it?Weld like a "WELDOR", not a wel-"DERR" MillerDynasty700DX,Dynasty350DX4ea,Dynasty200DX,Li  ncolnSW200-2ea.,MillerMatic350P,MillerMatic200w/spoolgun,MKCobraMig260,Lincoln SP-170T,PlasmaCam/Hypertherm1250,HFProTig2ea,MigMax1ea.
Reply:It was pretty cool.
Reply:I just started TIG welding too and if i showed that to my instructor he would say what are you running? But yeah TIG is a new process to me too but catching on fast and it is different, really tedious but cool
GMT+8, 2025-12-29 05:16 , Processed in 0.127484 second(s), 18 queries .
