Plasma Cutter!
发表于 2021-8-31 22:53:46 | 显示全部楼层 |阅读模式
Whats a good Plasma Cutter with a 3/8 in cutting capacity that relatively inexpensive?
Reply:here we go again..............
Reply:Here we go!
Reply:From what i have read here...  Hypertherm, thermal dynamics, miller, (hobart?)  If it is important to you to buy locally for support that should be a major consideration.  Oh yeah, try doing a search on this.  There have been multiple threads in the past months.
Reply:Type in "Chinese plasma cutter" in your Google bar. That will give you enough information to confuse you. Your mind will be travelling in circles for a few weeks. Riland has some good reviews. If you look at Nick Kent's recommendations you will not find any bad reviews........
Reply:There's no such thing as a "good Plasma Cutter with a 3/8 in cutting capacity that relatively inexpensive".  Unless you find one from an individual that don't have a clue what they have.DewayneDixieland WeldingMM350PLincoln 100Some torchesOther misc. tools
Reply:I`d like to know if a hand plasma cutter will cut copper sheet up to 3/16".Never saw one working, but I need input from someone who`s used one with copper. I`ve been told it`s messy! What really happens to the cut sheet? Does it warp or get spatting that bad? What capacity plasma cutter is needed ? THANKS FOR HELP GUYS.Baculus
Reply:Originally Posted by baculusI`d like to know if a hand plasma cutter will cut copper sheet up to 3/16".Never saw one working, but I need input from someone who`s used one with copper. I`ve been told it`s messy! What really happens to the cut sheet? Does it warp or get spatting that bad? What capacity plasma cutter is needed ? THANKS FOR HELP GUYS.Baculus
Reply:Their is tons of info all ready here. Just do a search.As far as I am concern, Hypertherm and Thermodynamics are the two best plasma's out there. They do more reseach and developement then any other brand and stand by the products. I did a lot of research when I bought mine. I tried the hypo 380 and the TD 38. I ended up with the TD 38 as it had a little better cutting qualities and the consumables were half the price. Their are a couple new models of for both these brands so you might want to check them out. If you are going for the cheaper brand or off shore units, I would PM GiantTechGuy who is a member here as he seems to stand by his products.Thats my 2 cents worth.Good luck and have fun.Last edited by jamlit; 02-15-2008 at 02:57 PM.Miller DVI2Lincoln Precision Tig 225Thermodynamics Cutmaster 38Everything else needed.
Reply:You can have an inexpensive one, or a quality one but you can not have both...Me!
GMT+8, 2025-12-29 03:30 , Processed in 0.094156 second(s), 18 queries .
