Will the type of bender I'm linking below bend oil field pipe like 2-3/8" or 2-7/8" or does it take something much more substantial? I don't have a lot of bending so speed wouldn't be that important but I don't want to get a useless piece of scrap either.http://cgi.ebay.com/ebaymotors/16TON...spagenameZWDVWHH 187Miller Bluestar1EAHP AlphaTig 200X
Reply:It should handle sch. 40 line pipe just fine. If you try to bend tubing (oil well) that is a lot tougher stuff, even J-55, and will probably do bad things to it.
Reply:This is for bending automotive-type exhaust pipe, which is thin-wall. No way is it going to bend oilfield tubing.America Needs AMERICA'S Oil!!!"Global warming is the greatest scam in history ...There is no run away climate change. The impact of humans on climate is not catastrophic. Our planet is not in peril."--John Coleman, Founder of The Weather Channel
Reply:Originally Posted by steve45This is for bending automotive-type exhaust pipe, which is thin-wall. No way is it going to bend oilfield tubing.
Reply:I've seen the ebay one you linked to. It will bend fairly heavy pipe but the shoes wont fit what you want to bend. 2" is about the physical limit for width. You're biggest problem will be finding shoes to fit the pipe. You may have to have shoes custom made $$$. Here's a link to a project I'm working on. Seems to be able to bend anything, again your trouble will be the shoes. If you dont have much bending try looking up someone local who races and makes roll cages. Good luck.http://www.pirate4x4.com/forum/showthread.php?t=376183Latest Toys Miller 180 Mig and Elite Mask!!Wright Welder 225ACShop OutFitters 20/20 Bending SystemHypertherm 380 Plasma30 Years of Sparking (Electrical & Welding)
Reply:Thanks for the replies guys, sounds like it really won't do what I would like it to.HH 187Miller Bluestar1EAHP AlphaTig 200X
Reply:The 16 ton is made to bend sch40 pipe up tp 3" ID. Pipe capacity: 1/2'', 3/4'', 1'', 1-1/2'', 2'', 2-1/2'', and 3'' pipesHF sells one. I have one from Homier. Got it for $75 it was missing the 2.5" die. I've bent a lot of 2" pipe (2-3/8"OD) with it. I cut some pads for the outer rollers out of a short section of pipe and that really helps prevent denting by the rollers. http://www.harborfreight.com/cpi/cta...emnumber=35336Pipe dimensione here to figure out the OD's it's made for.http://www.snapfour.com/pdf/Table_38-39.pdfLincoln SA200, HH135, Lencospot, HF80 Inverter, Rockwell 11x35 lathe, HF drill mill, Kama 554 tractor w/ FEL & BH, Belarus 250AS, lot's of Chinese tools
Reply:Originally Posted by GreyhorseWill the type of bender I'm linking below bend oil field pipe like 2-3/8" or 2-7/8" or does it take something much more substantial? I don't have a lot of bending so speed wouldn't be that important but I don't want to get a useless piece of scrap either.http://cgi.ebay.com/ebaymotors/16TON...spagenameZWDVW
Reply:Originally Posted by RojodiabloQuite the opposite. It is not a mandrel bender for thin wall tube. It is made to bend pipe in the field. It's a 16 ton press, which will bend sched. 40 with no problem. Only question is if it will handle anything over 2" in Dia. That would be the real question!!
Reply:Oilfield line pipe is MILD steel. They only use stainless where it is really needed. Blast joints, highly corrosive chemicals, etc.The difference between art and craft is the quality of the workmanship. I am an artist.
Reply:I've bent some 2" SS Sch10 with success. Also some 2" boiler tubes that are not as thick as sch 40. It ripples a little on the inside of the bend but usually does not kink. The times I had a kinking problem were with the boiler tubes where there was serious corrosion/non-uniform walls. I am not familiar wiith oilfield pipe but the ODs mentioned seem to correspond with NPT 2" and 2.5" sizes. I guess someone just has to try it and see. Here is a gate I made from the 2" boiler tubes. It is 7' tall x 16' wide.Lincoln SA200, HH135, Lencospot, HF80 Inverter, Rockwell 11x35 lathe, HF drill mill, Kama 554 tractor w/ FEL & BH, Belarus 250AS, lot's of Chinese tools
Reply:Wow!!!All the Boilers I work with are Sch80 pipe.....Miller Thunderbolt 225Millermatic 130 XPLincoln HD 100 Forney C-5bt Arc welderPlasma Cutter Gianteach Cut40ACent Machinery Bandsaw Cent Machinery 16Speed Drill PressChicago Electric 130amp tig/90 ArcHobart 190 Mig spoolgun ready
Reply:Originally Posted by Jolly RogerOilfield line pipe is MILD steel. |
