Need a little help
发表于 2021-8-31 22:53:40 | 显示全部楼层 |阅读模式
looking for a place in Illinois that has sa-200 parts. mans name is Stumpf I believe. has numerous parts machines..thanks.GRB
Reply:I found the following in a list of Lincoln shops.MASCOUTAHStumpf Welding Supplies8144 State RT 4Mascoutah, IL 62258PH.(618) 566-4733FAX.(618) 566-4734You may also want to check Weldmart on line, http://www.weldmart.com, Lots of SA-200 stuff there.For Continental Engine parts, I hear Continental Engine Inc. is pretty good. http://www.continentalengines.com/ce...anu_wiscon.aspCheers,
GMT+8, 2025-12-29 03:31 , Processed in 0.183440 second(s), 18 queries .
