Welding B16 grade 2" diameter threaded stud.
发表于 2021-8-31 22:53:36 | 显示全部楼层 |阅读模式
Howdy,Hoping for some metallurgy advice here. I needed some screw jacks for a job, and decided to make my own heavy duty ones. I caught these  2" by 9" studs for cheap on clearance and trying to get the most  out of the deal. The B16 grade apparently stand for  heat treated 0,50 % carbon, CrMoV alloy, which withstands temp up to 750 - 1100 degrees Fahrenheit without losing the properties, according to different sources on the web.   I can use them as is, but I would like to weld on some pipe extension, unless im gonna lose much of  the strength.  Could I preaheat and stick weld them?   Or may be tig braze them for less heat input?The load would be along the axis, so the welds wouldnt need to be terribly strong, but I wanna do it the best way. Oh, btw  I have some 309ss  and even a few certanium rods I picked up at a garage sale.  They were stored in a regular plastic rod tube, and I wonder if the go bad with air exposure? Never stick welded stainless, but have decent amount of experience with 7018 and 6011. Thanks a bunch.DC.Thermal Arc Fabricator 181IDayton 230/140 stickEvolution 14" dry sawafter  12 years of wood work, realized that the best wood working tool is a welder.
GMT+8, 2025-12-29 03:31 , Processed in 0.098400 second(s), 18 queries .
