Heavy Duty SawHorses
发表于 2021-8-31 22:53:27 | 显示全部楼层 |阅读模式
heres some saw horses I made outta 1" pipe and unistrut, the sleeves that allow them to swivel are like 1 1/2" or something I don't remember, but they are very sturdy and solid, u can bolt 2x4s to the top so as you have no fear while ripping plywood or whatever, the ones I built have had about 1500 pounds on em and they held  good, any way heres a pic thought someone would like to see a well built saw horse for heavy duty use, cant buy them like this at the box storesMiller Syncrowave 210 w/CK FlexLoc 150  3/6/14ESAB PCM 1125 Plasma CutterAtlas 12x36 LatheACER 9x42 3hp millHarig 612 Surface GrinderDRINK Machine              welding&fabrication
Reply:I like those saw horses.   They would be handy around my shop . Richey   sweet home alabama
Reply:Nice portable design!Lots of other designs in this thread:http://weldingweb.com/vbb/showthread.php...ghlight=horses- MondoMember, AWSLincoln ProMIG 140Lincoln AC TombstoneCraftsman Lathe 12 x 24 c1935Atlas MFC Horizontal MillCraftsman Commercial Lathe 12 x 36 c1970- - - I'll just keep on keepin' on.
Reply:Nice clean design. Thanks.
Reply:They  held 1500 lbs.  Wow!  I'm building a rack for my truck now, from 1 5/8 tube (material from Fence Co across the way from me).  I should be good to go, as I'm only planning on loading it with a maximum of 600 lbs.-AaronJet 17.5" Drill Press1942 South Bend 16x84 Lathe1980s Miller 320A / BP --- 2013 Power Mig 2562012 Jet 7x12 Horizontal BandsawVictor O/A Setup
Reply:I didn't make it outta tubing I made it outta pipe so the nominal sizes aren't like what tubing guys are used to  1.5in pipe is like 1.925 od I used smaller not thinwall but I was knda worried with all that wieght in em since a welder and his helper was usin em if they'd have broken I wouldn't be allowed to make stuff like that at work oil and gas companys are like that ya knowYou should be way good my dad made his own rack outta square tube and put garage doors on it so well over 600 lbsLast edited by chevydyl; 05-31-2013 at 04:43 PM.Miller Syncrowave 210 w/CK FlexLoc 150  3/6/14ESAB PCM 1125 Plasma CutterAtlas 12x36 LatheACER 9x42 3hp millHarig 612 Surface GrinderDRINK Machine              welding&fabrication
Reply:The foldup design is real handy.  AND PAINTED TOOMade these crappy looking old things probably 12-15yrs ago when I was building the loader.Was back in the day before I really got the lowdown on the right way to do it.  I used to whip like a banshee  And I really NEVER saw the puddle because I didn't really know what to look for  I used to weld observing the slag while running the bead.  I found that after a number of times I could pretty well predict what was underneath the slag.  It was a half azzed way of doing things.  But it worked..............sorta  Been a lot of water under the bridge since those days.  It's why I always envy the guys that have been to a school, was hard to learn on my own.Anyways, I like your horses"Any day above ground is a good day"http://www.farmersamm.com/
Reply:Great looking saw horses, very helpful around the shop. It's convenient to move and store as well with the chains. Great project.
Reply:Great design.
Reply:Nice! I love unistrut.
Reply:I have been using a set of these..Brenner Military Litter Stretcher Stands Supports (2) Each Alum Folding SawhorseWork great for me.....From the desk of Kevin CaronTrying to be the best me I can!www.kevincaron.comAHP Alpha Tig 200x MillerMatic 251Miller Syncrowave 200
GMT+8, 2025-12-29 03:30 , Processed in 0.093637 second(s), 18 queries .
