6 g uphill 6010 root ? + pic
发表于 2021-8-31 22:53:23 | 显示全部楼层 |阅读模式
Here is part of my root pass - not flat - good penetration on inside - 1/16 gap - running it about 85 amps - I think - using a 56 shorthood - any tips / comments ?? thanks! Dave[IMG][/IMG]
Reply:Uhh. Show us the back side. Looks good, but what really matters is whats on the inside.
Reply:Insane cold, your doomed!I hate being bi-polar it's awsomeMy Heroes Have Always Been Cowboys
Reply:Originally Posted by weldermikeInsane cold, your doomed!
Reply:3/32'' gap is better,amps ok, smooth bead profile will eliminate the excessive grinding you gonna have to do to eliminate wagon tracks!
Reply:I always preferred  a 3/32 gap and 3/32 land.  Somewhere around the 75-80 amp mark with a steady forward direction. Unless my keyhole got too big, then I would whip.  Show a PICT of he backside
Reply:Looks like the bead is too concave and not flat enough. Wet out on the sides looks marginal and appears to have lots of slag buried in there. That slag will fail you when it comes time to bend your coupons. The weld will open right up after bending.JasonLincoln Idealarc 250 stick/tigThermal Dynamics Cutmaster 52Miller Bobcat 250Torchmate CNC tableThermal Arc Hefty 2Ironworkers Local 720
Reply:Originally Posted by snoeproeLooks like the bead is too concave and not flat enough. Wet out on the sides looks marginal and appears to have lots of slag buried in there. That slag will fail you when it comes time to bend your coupons. The weld will open right up after bending.
GMT+8, 2025-12-29 03:29 , Processed in 0.099723 second(s), 18 queries .
