White and Brown band Tungsten
发表于 2021-8-31 22:53:20 | 显示全部楼层 |阅读模式
Why is there two different colors for the same spec tungsten? EWZr-1...talk about confusing!
Reply:Zirconiated should be only brown. That I know ofLast edited by n0ctrnlr3d; 03-01-2013 at 02:37 PM.
Reply:Take a look at this site...up at the top part of the page under the package of tungsten. It lists the colors to the type of tungsten and then it says White OR Brown...1% Zirconiated... I'm having troubles understanding why this would be done? It has caused alot of un-wanted BS trying to locate white band. I had the welding shop scratching there heads for two days...and myself.http://weldingdirect.com/turoelandpr.html
Reply:here is the AWS PDF on Tungsten classification http://files.aws.org/wj/2008/01/wj200801/wj0108-46.pdfAWS Alloying Alloying AlloyingClassification Color(a) Element Oxide Oxide %EWP Green — — —EWCe-2 Orange Cerium CeO22EWLa-1 Black Lanthanum La2O31EWLa-1.5 Gold Lanthanum La2O31.5EWLa-2 Blue Lanthanum La2O32EWTh-1 Yellow Thorium ThO21EWTh-2 Red Thorium ThO22EWZr-1 Brown Zirconium ZrO20.25EWG Gray Not Specified(b) — —Now remember this is the american welding society standard not what ever europe or other countries use my guess is those are china tungstenLast edited by WeldorWes; 03-01-2013 at 10:18 PM.Miller Xmt 350Lincoln Ln-25Ahp 200xSmith Gas Mixer AR/HTig is my Kung FuThrowing down dimes and weaving aboutInstagram http://instagram.com/[email protected]
Reply:The new ThermalArc 186 specs the white band tungsten for AC welding. I had never heard of it before then, obviously after many calls visits I wasn't alone! The specs read the same for the both Brown or White. I will try and get a solid answer why they are making the same product with different color codes.
Reply:I read someplace that different colors for the same tungsten is the standard for the states and the standard for overseas are different. Not sure how true it is. I'll see if I can find where I read it at.Torchmate 2x2 CNC with Flashcut CNC controlsHypertherm Powermax45 Esab ET220i Razorweld 195 MigRazorweld 200ac/dc TigTormach 770, Tormach xstechRazorweld, Vipercut/Vipermig, SSC Foot Pedal Dealer
Reply:Zi is white in the EU.Syncrowave 300Maxtron 450, S-52E, 30A
Reply:Not sure but I think white might be that Rare Earth, ask Terry he will know....  Miller Dynasty 350Twenty Six HammersThree Crow BarsBig Rock
GMT+8, 2025-12-29 03:29 , Processed in 0.100536 second(s), 18 queries .
