flux core mig technique
发表于 2021-8-31 22:53:18 | 显示全部楼层 |阅读模式
What's the proper way to run flux core? Can you whip it or do you run it like a 7018? Is it proan to slag inclusions?
Reply:Don't whip like 6010, stringer beads or weave.REAL TRUCKS DON'T HAVE SPARK PLUGS
Reply:Thanks!
Reply:Push the puddle when FCAW.
Reply:Originally Posted by Tat2dHandzPush the puddle when FCAW.
Reply:I don't have much experience with self shielded flux core or the dual shield but with regular mig, the instructors tell us always drag on steel unless you don't want deep penetration. It seems like since your already on dcen with self sheilded wire that a drag would be better for more penetration because the polarity is alread limiting it some. But that's just a guess....
Reply:It is more for the slag, you want to force the slag behind the puddle. Don’t pay any attention to meI’m just a hobbyist!CarlDynasty 300V350-Pro w/pulseSG Spool gun1937 IdealArc-300PowerArc 200ST3 SA-200sVantage 400
GMT+8, 2025-12-29 05:07 , Processed in 0.112101 second(s), 18 queries .
