Circle/hole cutting guide
发表于 2021-8-31 22:53:14 | 显示全部楼层 |阅读模式
I have looked all over and cannot find a circle/hole cutting guide that bolts to my torch. it has a sharp pointer that sets in a punch hole, and it holds the torch while you cut.Any leads appreciated.Perry
Reply:I should have said, it holds the torch steady while you cut out a circle.
Reply:This is the one for my Hypertherm plasma TORCH.http://store.weldersource.com/hycicugu.htmlBut you really didn't indicate brand preference or even whether for plasma or fuelgas torch.Last edited by 69 chevy; 02-29-2008 at 01:06 PM.
Reply:I have a store bought one but mostly use one that is made from a split bolt with a piece of rod welded to it and sharpened..... easy to make.
Reply:$110, no thanks, I'll build one.
Reply:flange wizard, chariot guide, just bought one but haven't had a chance to use it yet
Reply:Before acetylene bottles came with hand wheels we used to build them out of bottle wrenches and a piece of keystock with a nut welded on one end. I can't remember the last time I saw a bottle wrench.
Reply:http://www.weldingweb.com/vbb/showthread.php?t=17096   Victor SuperRanger O/A                                         Solar migLincoln Powermig 140Southbend 9in lathe350# kohlswa anvilMiller Maxstar 150 stl etc....
Reply:Make one like this.http://i94.photobucket.com/albums/l1...tleHook009.jpghttp://i94.photobucket.com/albums/l1...tleHook010.jpgMy handy dandy hole cutter.Disclaimer; "I am just an a$$hole welder, don't take it personally ."
Reply:Originally Posted by OldtimerBefore acetylene bottles came with hand wheels we used to build them out of bottle wrenches and a piece of keystock with a nut welded on one end. I can't remember the last time I saw a bottle wrench.
Reply:Heres one I made for my plasma cutter. I don't know what the telescoping rod was to begin with, I found it in a buddy's scrap pile. The base is a speaker magnet with a bearing epoxied on top. The rod is epoxied to the bearing. It will cut circles from around 6" diameter to 6' in diameter.Miller EconotigCutmaster 38Yes ma'am, that IS a screwdriver in my pocket!
GMT+8, 2025-12-29 03:30 , Processed in 0.099178 second(s), 18 queries .
