Markal Silver Streak Pens
发表于 2021-8-31 22:53:13 | 显示全部楼层 |阅读模式
I have been using the Markal Silver Streak Pens for a long time, I was In Tractor Supply, and I saw in the welding section, the pens being sold in a Hobart labeled blister pack. The pen and 6 refills is about $5, my LWS also sells them for $4 for the pens and $3 for the refills. The pens produce a thin silver line that is resistant to rubbing off and is easlly visible when using a torch or a plasma cutter.Pen #96006, refills #96007http://www.markal.com/ProductDetails104.aspxJack Attached Images
Reply:I've never used the pens but have used the silver, blue and red layout pencils. Much better than soapstone for some things.The difference between art and craft is the quality of the workmanship. I am an artist.
Reply:use a starette scribber...Unit in my fab shop dept:my good hand and team that trust me...A lone welder make art... a village full of welder make Miracles...
Reply:Originally Posted by westlawn5554xuse a starette scribber...
GMT+8, 2025-12-29 05:18 , Processed in 0.102761 second(s), 18 queries .
