Lincoln Pro-MIG 135A welder
发表于 2021-8-31 22:53:10 | 显示全部楼层 |阅读模式
Lincoln Pro-MIG 135 welder, like new- 110V, 20% duty cycle, gas or gasless capable, works with .023, .025, .030, .035" wire, with regulator and new spool of gasless wire- $340.I don't think I can pack this thing for shipping, so it would be local pickup only. I could possibly meet you part way depending on where you are.  I'm in the Peoria, IL area.It doesn't come with a bottle, but I have one if you want to try it before you buy it. It's designed to work with mild or stainless steel or aluminum, but I've not tried it with anything but mild steel. It's good for up to 3/16" thick material.Click on the thumbnail pics below for much larger pictures
Reply:The welder has been sold.  Thank you!
GMT+8, 2025-12-29 07:01 , Processed in 0.179568 second(s), 18 queries .
