How to tell welding tank is in date?
发表于 2021-8-31 22:53:05 | 显示全部楼层 |阅读模式
Looking at buying used Oxy and Acetylene tanks and getting them filled.  I believe that they have to be within a certain inspection date for someone (praxair, airgas, some other welding supply store) to fill/exchange them.  Question - what should I look for on the tank prior to buying to know that I can get them filled?thanks for the education guys!  I'm learning more every day
Reply:I'd Google it. I find that is not always straight forward.Regards,RobGreat Basin WeldingInstagramBlue weldersRed weldersMy luscious Table DIY TIG Torch cooler
Reply:Originally Posted by Robert HallI'd Google it. I find that is not always straight forward.
Reply:The most conclusive info I have found on hydrotest certs was a vid from a texas LWS. If I remember, ill dig it up on youtube. Call your gas supplier ahead of time. Might be a waste of money if they wont take an "owner" tank, even with proper documentation.
Reply:That last link has some good info. Some of it is specific to Airgas.Something to note is that acet cylinders are different than any other and only carry a 5 year test.GravelThe difference between theory and practice is that in theory there is no difference.
Reply:from reading (more), it looks like even if a tank is out of date, it costs approx $30'ish to have them retested. so if i can find them cheap enough (or full) then it could be worth it
Reply:Originally Posted by GravelSomething to note is that acet cylinders are different than any other and only carry a 5 year test.
Reply:Originally Posted by rlitmanWhile that is true, I've found it to be irrelevant, as I have never had to pay for an acetylene cylinder retest, regardless of how old it was when exchanged.I pay between $10 and $15 for a recert.
Reply:I guess you could always get your own metal stamp kit and pound in your own date.  Not saying that's "right" nor would I condone that  but, I wonder if it's ever been done just to fool the local Airgas clerks. Lincoln Power Mig 216Lincoln AC/DC-225/125Miller  625 X-Treme PlasmaMiller 211 Forney 95FI-A 301HF 91110Victor Journeyman O/PMilwaukee DaytonMakita  Baileigh NRA Life Member
Reply:Correction to my earlier post. DOT apparently only requires acetylene bottles to be recertified every 10 years.GravelThe difference between theory and practice is that in theory there is no difference.
GMT+8, 2025-12-29 05:28 , Processed in 0.095511 second(s), 18 queries .
