soften up welding gloves?
发表于 2021-8-31 22:53:01 | 显示全部楼层 |阅读模式
i have a pair of leather gloves that i have been using for stick welding not that long. my problem is that last week my left hand got really close when i was welding and now the fingers are pretty stiff. its annoying and a pain in the butt to grab and use tools. is there any way to soften the glove up?
Reply:buy new ones and keep them away from the arc... you cooked them.elk skin and goat skin are softer and don't crust up as bad, but you may have screwed the poochTeach Ag Mech - Mike At Home:Lincoln Electric AC225Miller Challenger 172Gas AxeWork:eclectic bunch of 90's vintage blue boxes
Reply:Put em in the back up heap and call it a day.I hate being bi-polar it's awsomeMy Heroes Have Always Been Cowboys
Reply:Time to buy a new pair.....http://weldingweb.com/vbb/showthread.php...y-right-handedJust a couple welders, big hammers, grinders, and torches.Work will free you.Men in dirty jeans built this country, while men in clean suits have destroyed it. Trump/Carson 2016-2024
Reply:Your gloves have reached the point of no return!!!
Reply:Cut your finger off so you don't have to use that hole.Miller Maxstar 200 SDPiperliner #10 Gold
Reply:Originally Posted by Burnt GloveYour gloves have reached the point of no return!!!
Reply:Sew on a tig finger. 30+ yrs Army Infantry & Field Artillery, 25 yrs agoMiller 350LX Tig Runner TA 210, spool gunLincoln 250/250 IdealArcESAB PCM 500i PlasmaKazoo 30"  vert BSKazoo 9x16 horiz BSClausing 12x24 lathe20T Air Press
Reply:I started putting neatsfoot oil on a old pair of gloves. It is making them softer but the finger is still short.
Reply:stick a fork in them. they are done.i.u.o.e. # 15queens, ny and sunny fla
Reply:Yes you are right they will never be the same.
Reply:Heat is used to harden leather. Sometimes it is useful to make a hard stable shape, other times, such as drying leather boots by the fire it destroys them.
Reply:Originally Posted by teachagmechIrony? Sent by a dumb smartphone
Reply:Originally Posted by smilexelectricCut your finger off so you don't have to use that hole.
GMT+8, 2025-12-29 07:28 , Processed in 0.106287 second(s), 18 queries .
