More Grinder Fun, Hardfacing
发表于 2021-8-31 22:52:55 | 显示全部楼层 |阅读模式
I figured the 12VS needed to go out and pay for itself, so a few spools of wire and many hours later it did and then some.I had to build up all the leading edges, and re do the specific pattern on the rotorsThe feeder making moneyNow to build up and face the anvils, I posted them new 1000 hours ago in this thread,http://weldingweb.com/vbb/showthread.php...=hardsurfacingI like how the entire screen basked swings out of the machine.She should be good for another 1000 hours, this is nextDisclaimer; "I am just an a$$hole welder, don't take it personally ."
Reply:The pin on the smaller front jaw looks like it has wallowed out the hole by quite a bit.
Reply:Wish that type of machine was available here.  I watched the video.We burn our brush piles here, and very often wind up setting the countryside on fire"Any day above ground is a good day"http://www.farmersamm.com/
Reply:Nice, what wire do you use for the hard facing?
Reply:This time we went with Hobart FabTuff 960. If we don't like the way it holds up we will try something else.Disclaimer; "I am just an a$$hole welder, don't take it personally ."
Reply:Not for trees........engine blocks[ame]http://www.youtube.com/watch?v=JWxcJDONE_U[/ame]
Reply:You get all the fun jobs...Do they sell log length oak?...zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Zap, whatever you want he has, let me know.Disclaimer; "I am just an a$$hole welder, don't take it personally ."
Reply:that engine block shredder is cheating, they are using aluminum engine blocks.Vantage 500's LN-25's, VI-400's, cobramatics, Miller migs, synch 350 LX, Powcon inverters, XMT's, 250 Ton Acurrpress 12' brake, 1/4" 10' Atlantic shear,Koikie plasma table W/ esab plasmas. marvel & hyd-mech saws, pirrana & metal muncher punches.
GMT+8, 2025-12-29 07:28 , Processed in 0.108011 second(s), 18 queries .
