flux core and penetration
发表于 2021-8-31 22:52:49 | 显示全部楼层 |阅读模式
I was just watching a video on welding tips and tricks.com and jody said that flux core will actually give you better penetration than solid core. It seems backwards from what I would think because of the polarity.Anyone know why it has better penetration?
Reply:My understanding is that because of the protective atmosphere created by the flux, the arc is able to burn hotter. It's basically like SMAW with a smaller diameter electrode.What I don't understand is why I see very little difference in arc and penetration when I raise the voltage but keep WFS and Inductance at the same settings when using flux core. Does anyone know if the inductance should be high or low when using flux core?
Reply:Voltage controls the bead profile,wire speed controls amperage.
Reply:I tell ya what, I love the way lincoln 030 and hobart flux core run on my little machine! There wasn't much spatter at all and it pretty much welded like a 7018 with a short arc length. Very nice!Does anyone know if there is a difference in ductility or tensile strength between flux core and solid core?
Reply:Those are research questions of the mechanical properties for your particular wire.  Easy to find on the web.  But the short answer is they are both 70,000 psi wire.Dave J.Dave J.Beware of false knowledge; it is more dangerous than ignorance. ~George Bernard Shaw~ Syncro 350Invertec v250-sThermal Arc 161 and 300MM210DialarcTried being normal once, didn't take....I think it was a Tuesday.
Reply:Originally Posted by MinnesotaDaveThose are research questions of the mechanical properties for your particular wire.  Easy to find on the web.  But the short answer is they are both 70,000 psi wire.Dave J.
GMT+8, 2025-12-29 05:27 , Processed in 0.070185 second(s), 18 queries .
