CK super flex leak
发表于 2021-8-31 22:52:34 | 显示全部楼层 |阅读模式
I know it happens if you leave the cooler of..... but I have never done that and still found a leak today. I carefully cut the cover off of the hose and found what looks to be a dry rotted hose??It has no more than 10 hours of use on it and had no burn marks or any indication of damage to it other than the leak. Second thought was to just trim that section off and attach the hose back to the fitting but I don't know what kind of hose clamp I can use that will fit inside the fitting. It has to be pretty thin so a screw type hose clamp won't work. Any ideas? Attached Images
Reply:Email CK and see if they think it's a defect.Torchmate 2x2 CNC with Flashcut CNC controlsHypertherm Powermax45 Esab ET220i Razorweld 195 MigRazorweld 200ac/dc TigTormach 770, Tormach xstechRazorweld, Vipercut/Vipermig, SSC Foot Pedal Dealer
Reply:Call them.I do have the vp of sales email [email protected] edited by Robert Hall; 08-15-2014 at 11:24 PM.Regards,RobGreat Basin WeldingInstagramBlue weldersRed weldersMy luscious Table DIY TIG Torch cooler
Reply:I tried today but they were already closed. I'll have to wait until Monday I guess which really sucks since I need the TIG this weekend. I can't buy another torch since I don't have the money for that right now, and I'm a little concerned that if I cut it and try to repair it myself CK might not be willing to help... if it is even an option for them. Has anyone else seen one damaged like that?
Reply:Don't cut it. No way you will be able to re-crimp the copper cable back to that connectorTorchmate 2x2 CNC with Flashcut CNC controlsHypertherm Powermax45 Esab ET220i Razorweld 195 MigRazorweld 200ac/dc TigTormach 770, Tormach xstechRazorweld, Vipercut/Vipermig, SSC Foot Pedal Dealer
Reply:Well crap... figures it wouldn't work.
Reply:You can buy the crimp collars and crimp tool at you lws. Cut the old crimp off and reuse your fitting. You could also try fuel injection clamps, they are like hose clamps, but smaller and tougher. Available at most auto parts stores.Thermal arc 211iCk flex-loc 150 & 130Clamps, saws & grindersHarbor freight 80 amp inverter
Reply:Hey Chief - can you just use an air cooled 26 or 17 for the weekend?(assuming you have one in the drawer)I mostly weld nights and weekends so I need a backup way to do everything - just something to keep in mind as you accumulate welding gear. (in case you needed an excuse to buy something )Dave J.Beware of false knowledge; it is more dangerous than ignorance. ~George Bernard Shaw~ Syncro 350Invertec v250-sThermal Arc 161 and 300MM210DialarcTried being normal once, didn't take....I think it was a Tuesday.
Reply:I could,  if I had it here. I let a buddy borrow my 26...
Reply:Empty cooler and retain coolant. Add distilled water.Tie rag around hose and use the torch.  Keep adding water as you go. Let it leak.Fix it Monday.If it's rotted there it's prolly rotted elsewhere.  CK is very good about their products, they may replace it. As long as it's just seeping and you're getting flow to the torch, just let it leak and top off.Last edited by Drf255; 08-16-2014 at 04:24 AM.
Reply:I'm not going to use it.  If there is even a remote chance that CK would warranty this, I don't wan't to kill that possibility by using something that I know to be bad.
Reply:I sent them an email with pics this morning.
Reply:I think this picture shows the damage better than the last few I posted. What could have caused this? Attached Images
Reply:@ CHIEF - root cause? Infant mortality.  You paid for customer service.  Cease any further destruco to the setup.  Contact CK and send it.  They're a solid crew."Discovery is to see what everybody else has seen, and to think what nobody else has thought" - Albert Szent-Gyorgyi
Reply:Originally Posted by CHIEFI think this picture shows the damage better than the last few I posted. What could have caused this?
Reply:This. Mixed 50/50 with DI water. Attached Images
Reply:I forgot to update this thread. The failed hose was replaced at no cost by CK!Great customer service which reaffirms my choice to have all CK products at home and the shop!
GMT+8, 2025-12-29 05:28 , Processed in 0.096006 second(s), 18 queries .
