Bobcat 225 intake cover
发表于 2021-8-31 22:52:25 | 显示全部楼层 |阅读模式
The plastic cover over the intake is gone.Probably blew off going down the road from improper installation. (Not by me)So twice now I've had to pull the plugs to pump out the water.So I build an installed this cover.Ps this is a machine at work on a service truck. The machine I use is newer and has a cover factory from miller.
Reply:Looks like your missing the top half of the air cleaner housing as well but the cover should help.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
GMT+8, 2025-12-29 07:09 , Processed in 0.078993 second(s), 18 queries .
