peacock
发表于 2021-8-31 22:52:23 | 显示全部楼层 |阅读模式
This is my first attempt at a peacock and probably the last unless someone offers silly money. Ive built the armature and started doing the feathers and each one of those takes a bout an hour to do. Built with 6 mm spine and 2mm old welding rods cleaned and tacked on, horrible job. I cut out stainless discs from an old twin wall stainless chimney and heat treat the middle for the "eye" Its gon be a while before this one is done but i will post progress pics if anyone interested Attached Images
Reply:Looks good, thats a lot of work there. What are you going to use for the body?
Reply:Yeah, wow, lotta bitty welds there. Looks nice though!200amp Air Liquide MIG, Hypertherm Plasma, Harris torches, Optrel helmet, Makita angle grinders, Pre-China Delta chop saw and belt sander, Miller leathers, shop made jigs etc, North- welders backpack.
Reply:Looks great Shirazman! I look forward to seeing project as it progresses!-Dan
GMT+8, 2025-12-29 07:01 , Processed in 0.175236 second(s), 18 queries .
