Welding Stainless to Carbon Steel
发表于 2021-8-31 22:52:19 | 显示全部楼层 |阅读模式
I work for a ground storage tank/pressure tank building company and was asked to weld stainless clips to the inside of a mild steel ground storage tank on Friday.  I was using 309L rods, the location of the clips only allowed me to use a stick welder, and I am having a lot of porosity.  I cleaned the area well, on both the tank and the clips, and I'm running the 1/8 rod at about 120-125.  The weld itself doesn't look too bad except for random spots of porosity.  The welds are horizontal, one weld on the topside of the clip and one on the bottom side of the clip.  Any tips to make the welds better?Matthew MortonTexas A&M '06Logsdon Seminary '13"Who Dares Wins""AFTF""WH2PH"SA 200 (Code: 5337)TB 302CP 302 w/22A Wire FeederMillerMatic 200Miller Syncrowave 200MillerMatic 252BurnTables 4x4 CNC MachineHypertherm 65
Reply:Are the rods dry ?  Were they left out of the oven an pick up moisture ?  I find stainless electrode don't handle moisture near as well as 7018.  If everything is cleaned up id imagine wet rods could be the issue,  stainless rods are low hydrogen afterall..Journeyman / Red Seal Welder (What a useless test)Miller CST 280Miller XMT 350Miller 12vs XtremeEvolution Evo 28 mag drillEvolution 380 Dry Cut saw
Reply:Also stainless rods run at lower current than steel rods, try turning it down to 80 - 90A.JohnA few weldersA lot of hammersA whole lot of C-clamps
Reply:Thanks for the response.  I'll definately try cooling things down a tad.Matthew MortonTexas A&M '06Logsdon Seminary '13"Who Dares Wins""AFTF""WH2PH"SA 200 (Code: 5337)TB 302CP 302 w/22A Wire FeederMillerMatic 200Miller Syncrowave 200MillerMatic 252BurnTables 4x4 CNC MachineHypertherm 65
Reply:Also keep rod as close as you can, stainless rods don't like a very long arc.
GMT+8, 2025-12-29 05:28 , Processed in 0.072203 second(s), 18 queries .
