Miller 212 spool issues
发表于 2021-8-31 22:52:18 | 显示全部楼层 |阅读模式
Seems my Miller 212 was not feeding right and it appears the wire drive wheels are doing all of the work and the wire spool isn't turning. Is this an easy fix? Is there a belt or something that drives this? Any advice, I have yet to take the panel off.......“It ain’t what you don’t know that gets you into trouble. It’s what you know for sure that just ain’t so.” – Mark Twain
Reply:is it the 212 auto set mine had the same issue had to send it back to miller they fixed it had to put a new drive roll in it got it back worked fine does it ever sound like gears meshing together in the drive rollsMILLERMATIC 212 AUTOSETMILLER BOBCAT 250MILLER DIALARC HFMILLER 15A SPOOLGUNMILLER S32P WIRE FEEDERTHERMAL ARC 186 AC/DCPAKMASTER 100XL PLUS
Reply:Its the auto set model if that makes any difference“It ain’t what you don’t know that gets you into trouble. It’s what you know for sure that just ain’t so.” – Mark Twain
Reply:Bill, we posted at the same time, Yes autoset, no gears grinding“It ain’t what you don’t know that gets you into trouble. It’s what you know for sure that just ain’t so.” – Mark Twain
Reply:Remove the gun from the drive and see if it will feed. if it feeds, see if you can stop the wire by pinching it.Flip up the pressure roller and see if the wire is centered to the groove on the drive roll.See owner's manual on how to adjust. If it feeds and you can't stop it, you have a liner problem in the gun or a bad tip. Safety tip, The wire may be hot so keep the work clamp away or covered.
Reply:Originally Posted by ccawgcRemove the gun from the drive and see if it will feed. if it feeds, see if you can stop the wire by pinching it.Flip up the pressure roller and see if the wire is centered to the groove on the drive roll.See owner's manual on how to adjust. If it feeds and you can't stop it, you have a liner problem in the gun or a bad tip. Safety tip, The wire may be hot so keep the work clamp away or covered.
Reply:None of the Miller feeders or migs I've ever worked with have had the spool spindle powered. The spindle stays stationary and the wire simply gets pulled off the roll by the drive rollers..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:Originally Posted by BeendareI changed the tip and its a fairly new liner- maybe one roll of wire through it. The wire is in the drive roller groove.I am under the impression the spindle that holds the roll of wire rotates with the drive rollers- correct? Because it doesnt turn now, a lot of resistance. Seems like it has something to do with the added resistance and its making the wire slip when drive roller is feeding
Reply:if its under warranty still I would have it checked just to be sure the part they put on mine was pretty high that I rememberMILLERMATIC 212 AUTOSETMILLER BOBCAT 250MILLER DIALARC HFMILLER 15A SPOOLGUNMILLER S32P WIRE FEEDERTHERMAL ARC 186 AC/DCPAKMASTER 100XL PLUS
Reply:Originally Posted by 7A749Sounds like the spool hub is hung up.If I'm not mistaken, the new ones are pretty similar to the old ones.This post explains the order the spool hub goes together. Check it out for problems. It should have just enough tension to brake the wire when you stop welding. It is entirely independent of the wire drive.http://weldingweb.com/vbb/showthread.php?t=235031
GMT+8, 2025-12-29 05:26 , Processed in 0.098071 second(s), 18 queries .
