Roll bender
发表于 2021-8-31 22:52:13 | 显示全部楼层 |阅读模式
Hey guys I'm looking for a good manual roll bender any suggestions? something that could roll up to 2x2 square tube or so, I do a lot of ornamental gates
Reply:http://www.rolxtools.com/http://www.jansensupply.com/pdf/pg186-189.pdfThis style will do 2x2 square.The shop outfitters style is rated only up to 1/2" square-http://www.shopoutfitters.com/Shop_O...ngRoller2.html
Reply:thanks for the help, the first one looks the strongest
Reply:how thick is the metal ??( wall)
Reply:depends, I would say 1/8 at the very most and rarely
Reply:im looking to buy one too eastwood.com has one with diesfor round and sq. tubing up to 2 inch.shop outfitters says it gos to half inch but i think thats solid sq.s.o. looks the best made and i have there 20/20 bender its nice stuffill call them and see if you can only bend up to half inch tubingif so its no good to me, but look at eastwoods sq. diesthats what caut my eye
Reply:heres a pic of the sq. die Attached Images
Reply:The shop outfitters stuff is okay for flat bar the easy way, but no way would it do 2" square. The force required is squared when you double the size, in almost all metal bending applications.That means it takes 4 times as much force to bend 1" as it does 1/2", and 16 times as much force to bend 2" as it does 1/2".And all that force means every part has to be bigger and beefier.Here are two more large radius rolls for 2" square. Both work well for what you want.http://www.hawkebender.com/http://www.rdhs.com/products/tubingbender.htmlNeither are as cheap as the shop outfitters- however, unlike the shop outfitters, they will actually roll large square tubing.There is no free lunch.
GMT+8, 2025-12-29 05:28 , Processed in 0.072100 second(s), 18 queries .
