Machine extensions
发表于 2021-8-31 22:52:04 | 显示全部楼层 |阅读模式
Possibly the nicest machine extensions you will ever see! Got a blueprint to machine and weld up these bad boys. Needless to say it was a fun little side project. Makes me wonder what kind of machine these will bolt under. All I know is the company that asked for them makes their own multi million dollar tools. It was kinda hard to get the torch in some spots so the consistency isn't the greatest. 220 Amps3/32 ceriated#4 cupSo here ya go. Thanks for looking More on next post! Attached ImagesLast edited by tig_21; 06-14-2013 at 10:10 PM.Miller Dynasty 200Millermatic 211Instagram?.... find me @ WELD_MEDIC
Reply:Last pic shows parts decked to exact height within +/- 0.005 Attached ImagesMiller Dynasty 200Millermatic 211Instagram?.... find me @ WELD_MEDIC
Reply:You got some amazing skills!That looks awesome. I am just struggling with corners and positions like that.
Reply:Beautiful. Did you fixture these during welding or rely on the tack welds and order of weld? Did you have to straighten at all them prior to final facing?
Reply:^^ Thanks!No fixture to hold them in place just simply tack all the joints and I welded from the inner joints outwards slowly. There was some pulling and warping thats why I left the ends a little thicker so that I could deck them down after they were all welded and complete.Miller Dynasty 200Millermatic 211Instagram?.... find me @ WELD_MEDIC
Reply:Originally Posted by tig_21. It was kinda hard to get the torch in some spots so the consistency isn't the greatest. 220 Amps3/32 ceriated
Reply:Nice work.  This is the kind of stuff I used to get to see everyday.  Nice to see it again.  Is that cold rolled steel?
Reply:Originally Posted by welding_kidair cooled torch ??you need one of the adjustable TIG torches which can hold short pc of tungsten.like this one http://weldingweb.com/vbb/showthread.php?t=116911
Reply:Originally Posted by el bobNice work.  This is the kind of stuff I used to get to see everyday.  Nice to see it again.  Is that cold rolled steel?
Reply:nice welding, but i am curious to know more about why these were welded the way they were. it sounds like these are carrying load that is parallel to the axial of the holes from plate to plate. is this correct? if so then why all the heavy welding? was there a concern that the heavy vertical pieces would buckle? if there are no side loads then technically the center pieces only needed some light welds to hold them in place (the big plates have dado's in them).Last edited by welding_kid; 06-21-2013 at 03:49 PM.
GMT+8, 2025-12-29 05:28 , Processed in 0.074015 second(s), 18 queries .
