Big Balls....
发表于 2021-8-31 22:52:04 | 显示全部楼层 |阅读模式
Thought I'd share the simple pipe gate I just completed and installed today. Total length is 42 feet. The posts I fabbed from 8 inch H-pile which I stuck 4 feet deep in 2x4x4 concrete footings. They ain't going to move unless hit by a dump truck...which is a distinct possibility.Hinges are fabbed from 1/2" stock and the pivots are 7/8 rod in homemade bushings equipped with welded grease fittings. They operate smooth as a baby's butt. The finials I constructed by welding pyramids I made from 1/8" plate onto simple angle frames and topped by 8" hollow balls I purchased online. To fit the balls,  I used a 2 1/2" hole saw and drilled down through the top of the pyramids creating nice cozy seats. The balls were 1/8" thick and welded up sweet. Fun little project.... Attached ImagesPOVERTY...is the Mother of InventionMillermatic 211Millermatic 140Miller Thunderbolt XLArcOne 100STS inverter w/TIGThermal Dynamics 38XL Victor Oxy/AcetyleneJancy Slugger Holemaker IIJet 5x6 BandsawNever enough time & sleep.
Reply:Sweet!
Reply:That looks real nice and sturdy.........Got any detail pics of the hinges and homemade bushings......?Precision TIG 185 and MP 210Bobcat 225NTCutmaster 42O/A tanks.... 2 Argon tanks...... 2 C25 TanksFacebook...... F2 Metal WorksETSY....... https://www.etsy.com/shop/F2MetalWorksF2MetalWorks.com....... http://www.f2metalworks.com/
Reply:Originally Posted by FexalThat looks real nice and sturdy.........Got any detail pics of the hinges and homemade bushings......?
Reply:Hinges are very straightfoward and attached to main posts with 2 bridge bolts each. I slotted the top hinge axle holes slightly to allow the gates some up and down adjustment. Attached ImagesPOVERTY...is the Mother of InventionMillermatic 211Millermatic 140Miller Thunderbolt XLArcOne 100STS inverter w/TIGThermal Dynamics 38XL Victor Oxy/AcetyleneJancy Slugger Holemaker IIJet 5x6 BandsawNever enough time & sleep.
Reply:What is the main gate made out of?
Reply:"Thought I'd share the simple pipe gate I just completed and installed today."Made from metal.  -AaronJet 17.5" Drill Press1942 South Bend 16x84 Lathe1980s Miller 320A / BP --- 2013 Power Mig 2562012 Jet 7x12 Horizontal BandsawVictor O/A Setup
Reply:Very nice work, looks great.PROUD   AMERICAN
Reply:That looks strong  and balanced. I like the straight line across the top.
Reply:Thats a slick looking gate set up.   I saw one near here with a single post and it leaned in about 8 inches.  Nothing like the quality of the gate you have.  I may copy the bearings.richey
Reply:That looks amazing. Like Raider12 said......The straight top line is amazing
Reply:Thanks all, for the comments. Having a very small shop, I'm forced to build gates across four horses...with one ending up outside which I have to shim up to keep everything straight...which is really best done by eye.Looks good...is good. The most important lesson learned after building lots of these is to not overheat any one joint when welding up. After all is lightly tacked up, I weld all joints from 12 to 3 o'clock...flip unit over and do the same...but opposite and so on till all welded. If you get one joint too hot all at once you will hate yourself and warp the top chord...usually upward and/or sideways...essentially wrecking the job.  Very difficult to bring it back and will never be 100%. Happily, my gates usually come out near perfect...if I may say so myself.      There are few things in life uglier than sagging gates. Attached ImagesLast edited by SMC Weldcraft; 06-21-2013 at 04:59 AM.POVERTY...is the Mother of InventionMillermatic 211Millermatic 140Miller Thunderbolt XLArcOne 100STS inverter w/TIGThermal Dynamics 38XL Victor Oxy/AcetyleneJancy Slugger Holemaker IIJet 5x6 BandsawNever enough time & sleep.
Reply:Yes no one likes saggers.
Reply:LOL...was thinking it but did not want to go there. POVERTY...is the Mother of InventionMillermatic 211Millermatic 140Miller Thunderbolt XLArcOne 100STS inverter w/TIGThermal Dynamics 38XL Victor Oxy/AcetyleneJancy Slugger Holemaker IIJet 5x6 BandsawNever enough time & sleep.
GMT+8, 2025-12-29 05:28 , Processed in 0.100756 second(s), 18 queries .
