Built a table for english-First Project
发表于 2021-8-31 22:52:01 | 显示全部楼层 |阅读模式
So for my senior project our class had to learn something new, i already had a harbor freight 90 amp flux piece of garbage so i decided to learn how to weld. Decided to build a table, in my opinion it came out pretty cool for someone with basically no metal fabrication experience. Saving up for a thermal arc 211i, tell me what ya think. [attach][attach][attach][attach][/attach][/attach][/attach][/attach] Attached Images
Reply:I think it came out great for your first project. Next time cope all the corners.Torchmate 2x2 CNC with Flashcut CNC controlsHypertherm Powermax45 Esab ET220i Razorweld 195 MigRazorweld 200ac/dc TigTormach 770, Tormach xstechRazorweld, Vipercut/Vipermig, SSC Foot Pedal Dealer
Reply:That came together pretty nicely.You can plug those open ends by cutting little squares and welding them in. Use a magnet to hold them in place (flush) while tackingNext time cope all the corners.
Reply:Yes that's what i meant. haha. It's been a long day!Torchmate 2x2 CNC with Flashcut CNC controlsHypertherm Powermax45 Esab ET220i Razorweld 195 MigRazorweld 200ac/dc TigTormach 770, Tormach xstechRazorweld, Vipercut/Vipermig, SSC Foot Pedal Dealer
Reply:Thanks, when you mean cope, or miter, do you mean just cut 45's? i was planning on doing this but the chop saw i used did not cut very accurate, also i thought about cutting little squares out but was not sure what tool i could use to cut perfect squares, all i have are a few basic power tools nothing fancy.
Reply:But thanks for all the positive comments much appreciated
Reply:Originally Posted by jbratesThanks, when you mean cope, or miter, do you mean just cut 45's? i was planning on doing this but the chop saw i used did not cut very accurate, also i thought about cutting little squares out but was not sure what tool i could use to cut perfect squares, all i have are a few basic power tools nothing fancy.
Reply:"...i thought about cutting little squares out but was not sure what tool i could use to cut perfect squares, all i have are a few basic power tools nothing fancy."You can use a jigsaw with a metal blade on some sheet metal. Just make sure to use some form of oil when cutting. The table came out great!Last edited by Adam; 06-19-2013 at 06:35 PM.Reason: Forgot to add the quote. There ya go
Reply:I think it came out really good. I was going to only echo what others have said about closing up the holes on the end for a finished look.Good selection for a senior project. That table will last for your lifetime if taken care of.PapaLincoln Idealarc 250 (circa 1962)Lincoln Weldpak 155 w/Mig KitLincoln Squarewave TIG 175
Reply:Nice work, man! Props!
Reply:Looks nice.  I had better not let my wife see that and get ideas!  Great for first project.
Reply:That turned out really nice! Good job ! Keep them coming.PlasmaCam CNC cutterLathe and Band SawClamps
Reply:Did one similar, was going to put glass on top.  Ended up cutting a piece of Oak Plywood and set it on top like a piece of glass.For the ends yes cut them at 45degrees.Or cut a square.  It does not need to be a perfect fit.  Your weld will fill in gaps.Having said that however you do want it to be as tight a fit as possible.
Reply:Nice project.
Reply:thanks erebody, i showed it to my architecture teacher and he asked me to build him a counter top or the frame for a counter top, making 500 from it so im happy.
Reply:Great first project. richey
Reply:Very nice work.  -AaronJet 17.5" Drill Press1942 South Bend 16x84 Lathe1980s Miller 320A / BP --- 2013 Power Mig 2562012 Jet 7x12 Horizontal BandsawVictor O/A Setup
Reply:Very nice work. Personally A improvment i would do is go and get some felt pads or something for the bottom of the legs. I could easily see it scratching the floor.PROUD   AMERICAN
Reply:very nice work
Reply:Originally Posted by RaulDo  you mean miter the corners?  Coping is that backside cut that allows one to cheat  when installing moldings.
GMT+8, 2025-12-29 05:28 , Processed in 0.100350 second(s), 18 queries .
