MaxStar 200SD noise help.
发表于 2021-8-31 22:51:50 | 显示全部楼层 |阅读模式
Just got my outlet wired up for my Maxstar welded with it works great. My only concern is the noises while running and startup. I made a video on youtube here is the video.[ame]http://www.youtube.com/watch?v=bDuMeufPx_g[/ame]Are these sounds normal?Miller Maxstar 200 SDPiperliner #10 Gold
Reply:sounds exactly like my dyanasty, These inverters are noisy, sounds completely normal to me.
Reply:Originally Posted by ironmangqsounds exactly like my dyanasty, These inverters are noisy, sounds completely normal to me.
Reply:My Maxstar 150STL doesn't make much noise, I would try to make a video of it with my phone but I don't know how to post them.Airco Ac/Dc 300 HeliwelderMillerMatic 200 (stolen)Miller Maxstar 150STLMiller AEAD200LE (welding and generating power) Hobart MIG
Reply:Originally Posted by SquirmyPugMy Maxstar 150STL doesn't make much noise, I would try to make a video of it with my phone but I don't know how to post them.
Reply:Just my .02.  My Maxstar 200DX makes the same noises.  No problems so far.  As for the Dynasty 350, I can't tell because the water cooler is relatively loud (In other words, I don't hear the noise on the 350).Con Fuse!Miller Dynasty 350Millermatic 350P-Spoolmatic 30AMiller Multimatic 200Hypertherm PowerMax 1000G3Miller Maxstar 200DX
Reply:Originally Posted by smilexelectricI used my Ipod and sent it from my ipod to my youtube channel.
Reply:Originally Posted by SquirmyPugGuess I can try to find out how to send a video from my phone to youtube-How hard can it be?
Reply:Hope this works.[ame]http://www.youtube.com/watch?v=dczSTDUbm08&list=HL1363215011&feature=mh_l  olz[/ame]Airco Ac/Dc 300 HeliwelderMillerMatic 200 (stolen)Miller Maxstar 150STLMiller AEAD200LE (welding and generating power) Hobart MIG
Reply:Originally Posted by SquirmyPugHope this works.
Reply:Originally Posted by 7A749I was going to say something earlier, but I've never used a Maxstar 200 machine.I have repaired many older inverters & they all tend to squeal, so I would say yeas, that's common. PowCon & older Miller machines both make quite a bit of noise. This is the IGBT modules turning the rectified DC current into high frequency AC. Both Maxtrons & XMT 300 machines make a lot of noise at low amp outputs.Someone who has experience with the machine you have will be of better assistance, I'm afraid tho.
Reply:Originally Posted by smilexelectricI wonder if it is because the 200 is closer related to the dynasty and the internals are much more different than the dynasty and maxstar. That is definitely a quite unit, normally i dont get to hear machines run because im hearing the banging of chipping hammers and fume extractor running.  Also nice machine ^_^@con_fuse9thanks for your input, its greatly appreciated to know that 2 users experience the same sounds. I am extremely happy with my purchase of my machine.
Reply:Originally Posted by 7A749Neither does my XMT 304 or Maxstar 150.The older ones will scare the living crap out of you the first time you get it below 100 amps & strike an arc.
Reply:I just called Miller and had them check the Serial on my machine it left Miller in 2001, and only has 386 and 44  hours/min on the clock like 38552 arc strikes. I went on the Miller forums some of these guys with 2008 dynasty machines have 192 hours with 70k arc strikes. Has never been serviced before.Needless to say the guy had no clue what he had.Last edited by smilexelectric; 03-15-2013 at 02:37 PM.Miller Maxstar 200 SDPiperliner #10 Gold
Reply:A lot of the noise you are hearing is the PFC boost circuit working. The welder will sound different on 115 volt, 230 and 460 volts. On 460 volts they don't make much noise at all.The help 12 will always come on when you try to switch between TIG and stick with the output on. The maxstar 200 along with being a good DC TIG welder. IT is a very good stick welder. A story I heard at a lincoln school I went to. Said  when they saw the first inverters demonstrated They were very noisy. (powcon I assume). Lincoln went back to their Engineers and told them to build one that did not make any noise.You can get a Lincoln to squeal if you put to much load with them set low.
GMT+8, 2025-12-29 09:20 , Processed in 0.097877 second(s), 18 queries .
