update on my oxyfuel torch
发表于 2021-8-31 22:51:50 | 显示全部楼层 |阅读模式
well as you know i'm looking into getting a oxyfuel torch im gonna get the victor set off my buddy for 50 bucks once i look at it to make sure it's in good shape as far as the tanks i called my local airgas they said they would swap me tanks if i got my tanks online from someone else as far as gas i'm going with acetylene it's not cheap but i like to  braze and weld as far as size of tanks i'm getting a 40 cubic oxygen tank and a 40 cubic acetylene tank i know that's small but i'm not gonna use them everyday does anyone know what tips i  should use i  work with alot of 1/8 inch steel
Reply:From a tip chart I happened to have handy, a #2 or #3 Victor welding tip is about right for 1/8".  That puts you roughly in the range of maybe 8 - 10 CFH on the Acetylene for welding. Your acet tank should be an 80 or so based on withdrawal. Double-check the numbers with another chart."USMCPOP" First-born son: KIA  Iraq 1/26/05Syncrowave 250 w/ Coolmate 3Dialarc 250, Idealarc 250SP-175 +Firepower TIG 160S (gave the TA 161 STL to the son)Lincwelder AC180C (1952)Victor & Smith O/A torchesMiller spot welder
Reply:+1I was just going to say that for 1/8th steel you will need a larger acetylene tank. its the old 1/7th flow rule. You shouldn't withdraw more than 1/7th of the tank in an hour. For example a 40 cu ft tank can only safely support a flow rate of 5.7 cu ft per hour. A size 2 tip is rated for 1/8th in. steel, and flows between 5-10 cu ft per hour. You would be pushing the safety limits on that small tank. I would think you would be limited to nothing larger than a size 1 tip with that small tank.Miller Multimatic 255
Reply:40cf sized tank?????  You're gonna need a bigger "boat" there if your serious about even small O/A cutting.  Learn from this guy:[ame]www.youtube.com/watch?v=8gciFoEbOA8[/ame] "Hey I didn't come to look and learn, I came to turn and burn.... If I can't light up, I'm gonna light out!"-JodyIdealarc 250 "Fatman"MM 252MM 211 "Little boy" Victor Torches
GMT+8, 2025-12-29 07:28 , Processed in 0.074048 second(s), 18 queries .
