A356 Filler Rod
发表于 2021-8-31 22:51:48 | 显示全部楼层 |阅读模式
Hi, Does anyone have a couple of pounds of this filler they would like to sell? Can do paypal or cash. Thanks Dale 712-209-1600Miller 250DX HTP 221 DV AC/DCHenrob O-A Miller 180 MigMiller 150 Inverter   Hobart 10,000 Welder-Generator   Have a good day!!!
Reply:A 356 isb pretty hard to find. A357 will be easier to find. What are youb going to use it for?Weld like a "WELDOR", not a wel-"DERR" MillerDynasty700DX,Dynasty350DX4ea,Dynasty200DX,Li  ncolnSW200-2ea.,MillerMatic350P,MillerMatic200w/spoolgun,MKCobraMig260,Lincoln SP-170T,PlasmaCam/Hypertherm1250,HFProTig2ea,MigMax1ea.
Reply:Thanks I am using it to weld on cylinder heads. Have always had some and about to run out. I go to the welding store and they will not sell it in less then 20lbs at Matheson LW. Couple a pounds would set me up good for a while. Maybe the A357 would be a better choice? open for ideas or suggestions. Thanx DaleMiller 250DX HTP 221 DV AC/DCHenrob O-A Miller 180 MigMiller 150 Inverter   Hobart 10,000 Welder-Generator   Have a good day!!!
Reply:For anyone interested. I found a supplier for A356 filler rod. Crown Alloys in Madison Heights MI. 1800-521-7878 Will sell it by the pound. You may have to go through a dealer like airgas depending on your situation buisness wise. They will help you out there but not a problem at all. Daleexpensive thoLast edited by power; 03-18-2013 at 10:54 PM.Miller 250DX HTP 221 DV AC/DCHenrob O-A Miller 180 MigMiller 150 Inverter   Hobart 10,000 Welder-Generator   Have a good day!!!
GMT+8, 2025-12-29 07:28 , Processed in 0.074594 second(s), 18 queries .
