Looking for a small turning roll
发表于 2021-8-31 22:51:42 | 显示全部楼层 |阅读模式
I am looking for a small fixture or device that can accept pieces of round stock to be welded together. This will be used for TIG welding extremely small beads on medical tools. The fixture also has to have a stepper motor and a foot pedal would be ideal. Anyone know of someone out there that sells something like this, or should I just DIY?Thanks,
Reply:That would be an easy project with a motor/gearbox at least 60:1 a shaft and a small lathe chuck to hold the parts. Any ideas what sizes of parts? I can help if you need it...BobBob WrightSalem, Ohio  Birthplace of the Silver & Deming Drillhttp://groups.yahoo.com/group/southbend10k/http://groups.yahoo.com/group/sawking/1999 Miller MM185 w/ Miller 185 Spoolmate spoolgun
Reply:I would think that you can use a welding positioner with a lathe type chuck attached. This would give you the foot speed control you want. I believe you can get them for both vertical and horizonal turning. I think David R just got one maybe he'll chime in on this.You might also be able to adapt a small lathe to give you 2 centers to align everything and add a variable speed controler to it.
Reply:Here is the 60:1 motor diver for my scrolling machine which is the same drive for my slip rolls just turned on its side. You can make a positioner just like it vertical or horiz, and with a fiber coupling between the shaft and gearbox you could weld on it...Bob Attached ImagesBob WrightSalem, Ohio  Birthplace of the Silver & Deming Drillhttp://groups.yahoo.com/group/southbend10k/http://groups.yahoo.com/group/sawking/1999 Miller MM185 w/ Miller 185 Spoolmate spoolgun
Reply:Originally Posted by aametalmasterThat would be an easy project with a motor/gearbox at least 60:1 a shaft and a small lathe chuck to hold the parts. Any ideas what sizes of parts? I can help if you need it...Bob
Reply:You need one of these..They go from zero to 10 R.P.M.http://weldingweb.com/vbb/showthread.php...ght=PositionerI gave you the same info in "Intro's".....zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
GMT+8, 2025-12-29 07:28 , Processed in 0.077591 second(s), 18 queries .
