Lincoln G7 Gas welder for sale
发表于 2021-8-31 22:51:35 | 显示全部楼层 |阅读模式
225 amp AC, 210 DC,  200 amp CV, 7 KW generator.  Up to 30 amp 220 volt single phase.  2 cyl Onan engine.Automatic Idle up does not work.  Switch down, Idles.  Switch up, runs at goverened speed.  Otherwise fine.  I changed the oil frequently and took good care of it.$700,   $900 on trailer.Email droot 2 at rochester dot rr dot com.thanks David
GMT+8, 2025-12-29 07:29 , Processed in 0.071168 second(s), 18 queries .
