Aluminum Practice...........
发表于 2021-8-31 22:51:26 | 显示全部楼层 |阅读模式
Today I decided I needed to sharped the needle on the Aluminum TIG......8 weeks ago I had 8 weeks of effort in class......I decided to do Jody's Aluminum Drill........ the one where all his beads are perfect.........it was a great way to use the last 100 lbs of Argon in tank #1.......... I need more practice for sure............ and more often.........Brushed with a stainless brush for the pics...... you know.... to hide the spots where I touched.....PICS....... Attached ImagesPrecision TIG 185 and MP 210Bobcat 225NTCutmaster 42O/A tanks.... 2 Argon tanks...... 2 C25 TanksFacebook...... F2 Metal WorksETSY....... https://www.etsy.com/shop/F2MetalWorksF2MetalWorks.com....... http://www.f2metalworks.com/
Reply:I tried this once, but don't have patience to let it cool down in between passes.Torchmate 2x2 CNC with Flashcut CNC controlsHypertherm Powermax45 Esab ET220i Razorweld 195 MigRazorweld 200ac/dc TigTormach 770, Tormach xstechRazorweld, Vipercut/Vipermig, SSC Foot Pedal Dealer
Reply:I would kill to have a tig set up and practice. I would love to learn. I did a little working for the army but it was stick rod aluminum.
Reply:Not to bad.. Aluminum is the devil and it's all I weld... I can have a great day, and then I could have a **** day, and you can't hind the crap days when welding aluminum. lol!www.thefusionsolution.com
Reply:Looking great, I wish I could run a bead like that. I have yet to run a great bead on anything when using filler rod.
Reply:Originally Posted by GambleI tried this once, but don't have patience to let it cool down in between passes.
Reply:Dave that is good advise.......I will pack the next set in tighter......The plan is to fill the entire side..... then flip it over...... fill the entire side..... then flip it over....... fill it the other way...... Rinse....lather....repeat...........Precision TIG 185 and MP 210Bobcat 225NTCutmaster 42O/A tanks.... 2 Argon tanks...... 2 C25 TanksFacebook...... F2 Metal WorksETSY....... https://www.etsy.com/shop/F2MetalWorksF2MetalWorks.com....... http://www.f2metalworks.com/
Reply:Put enough layers on and you can sell the coupon as an Aluminum "billet". "USMCPOP" First-born son: KIA  Iraq 1/26/05Syncrowave 250 w/ Coolmate 3Dialarc 250, Idealarc 250SP-175 +Firepower TIG 160S (gave the TA 161 STL to the son)Lincwelder AC180C (1952)Victor & Smith O/A torchesMiller spot welder
GMT+8, 2025-12-29 11:03 , Processed in 0.109391 second(s), 18 queries .
