Water Cooled TIG Setup On The Truck
发表于 2021-8-31 22:51:25 | 显示全部楼层 |阅读模式
Finally got around to putting together a proper set up for TIG welding aluminum on my truck. After I cooked my WP-26 last year doing a heavy aluminum job, I started gathering up water cooled stuff. Here we are, all set up, gonna go to horrible freight later and get some parts to make a cart for the new "unit"Disclaimer; "I am just an a$$hole welder, don't take it personally ."
Reply:Miller seriously screwed themself by making the new TB DC only, I forgot how good this thing ran an aluminum TIG bead. I will be damned if I am buying a new engine drive and a Dynasty to do what this old machine does.Disclaimer; "I am just an a$$hole welder, don't take it personally ."
Reply:Originally Posted by TozziWeldingMiller seriously screwed themself by making the new TB DC only, . . .
Reply:There is another thing they left out.115v on the 14 pin plug.Correct me if I'm wrong, but doesn't the hf starter require 115v?
Reply:I need 2, 115v plugs and the 14 pin to run this setup.Disclaimer; "I am just an a$$hole welder, don't take it personally ."
Reply:Originally Posted by AMC724There is another thing they left out.115v on the 14 pin plug.
GMT+8, 2025-12-29 09:20 , Processed in 0.072133 second(s), 18 queries .
