Welding hastelloy C22 to 304L or 316L stainless steel
发表于 2021-8-31 22:51:12 | 显示全部楼层 |阅读模式
We are undertaking a product development project that welds .75dia x .19thk inserts into stainless steel and then machining a precision o-ring seal in the hastelloy. Our current intention is to machine a 30 degree bevel on the stainless counter bore that will nest the inserts. We have extensive stainless experience and some orbital welding of Hastelloy C22 tubing, but no hands on experience of C22 to stainless. Can anyone provide recommendations process paramenters including filler rod?Big thanks,Max
Reply:Max,You might find this useful.http://www.haynesintl.com/pdf/h2010.pdf
Reply:Very useful! Thank you HT2!!
GMT+8, 2025-12-29 09:22 , Processed in 0.099029 second(s), 18 queries .
