can i use brazing rods with a MIG?
发表于 2021-8-31 22:51:09 | 显示全部楼层 |阅读模式
I am working on an old MGA   and replacing body panels,  in some spots there are  Pin holes and i have been filling them with the mig. every once and a while the hole opens up and i use a steel welding rod to help fill it.....today i happened to notice that i had some brazing rods, can i use the brazing rods in the same fashion?bobs77vet/37ford4drEastwood digital TIG200HH190Lincoln Invertec 155sLincoln weldpak 100sears/craftsman (lincoln) 50a 240v buzz boxO/A rig Harris gaugesnexion cut 50 dxchicago electric (HF) 240v spot welder
Reply:Brazing doesn't fill gaps very well, the best bet would be cut to good metal and make a patch, then mig it in.Leo
Reply:Yeah get yourself a few steel sheet metal discs made up then hold them behind your holes in your work and use the MIG to tack them into place. In my younger years we used to stuff rags in the holes and Bondo over them. Looked good for a couple years until they started falling out. Then we had to stuff a few more rags and rebondo. Kept more then one car together that way for a long time.
Reply:get a magnetic copper backing plate and weld your holes whit it Attached ImagesLast edited by T E B; 03-15-2013 at 11:14 PM.TO INVENT  YOU NEED A GOOD IMAGINATION  AND A  PILE OF JUNK'' - THOMAS EDISONMost Of The Time People Don't see The Quality of a Good Job Unitl they see a Bad Job !! -Scott Esplin
Reply:Originally Posted by T E Bget a magnetic copper backing plate and weld your holes whit it
Reply:thks for the comments, but i cant cant get access to the back side of the pin holed areas.  thks bobbobs77vet/37ford4drEastwood digital TIG200HH190Lincoln Invertec 155sLincoln weldpak 100sears/craftsman (lincoln) 50a 240v buzz boxO/A rig Harris gaugesnexion cut 50 dxchicago electric (HF) 240v spot welder
Reply:Originally Posted by 37ford4drI am working on an old MGA   and replacing body panels,  in some spots there are  Pin holes and i have been filling them with the mig. every once and a while the hole opens up and i use a steel welding rod to help fill it.....today i happened to notice that i had some brazing rods, can i use the brazing rods in the same fashion?
Reply:They do make silicon bronze mig wire for mig brazing.  I can't recall who touted it as great at the moment, but apparently it's great for body work and grinds off much easier than steel mig wire.  Also less heat input and panel warp.  Look into it.TA Arcmaster 300CM3XMT 304S22P12 suitcase feederX-Treme 12VSOptima pulserTA161SMaxstar 150STLHypertherm PM45OP setupStihl 020AVP, 039, 066 Magnum
Reply:Originally Posted by Drf255They do make silicon bronze mig wire for mig brazing.  I can't recall who touted it as great at the moment, but apparently it's great for body work and grinds off much easier than steel mig wire.  Also less heat input and panel warp.  Look into it.
Reply:+1 Silicon Bronze mig, it melts at a lower temp than the steel and is a lot softer than a normal mig bead which makes working it down easier, your local LWS should be able to get it but it will probably be cheaper to order it from an online dealer.
Reply:There is also a mig wire by ESAB called easy grind that is for sheet metalBacked my CATMA over your CARMA oops clusmy me  What would SATAN do ?? Miller Trailblazer 302 AirPakMiller Digital Elite  Optrel Welding HatArcair K4000Suitcase 12RC / 12 VSHypertherm PM-45Rage 3 sawRusty old Truck
GMT+8, 2025-12-29 09:20 , Processed in 0.095298 second(s), 18 queries .
