Cracked open the new air arc.
发表于 2021-8-31 22:50:50 | 显示全部楼层 |阅读模式
Wow, that is FUN! Not nearly as loud as I had expected. I took a wild guess at the amp setting and used 235 amps with a round 3/16" carbon. It was easy to get a nice smooth "WHOOSH" after 1 or 2 passes, I had it down, nice and steady!! I only needed to see it work, now I have a new tool in the bag o' tricks. First pass, OH! City of L.A. Structural; Manual & Semi-Automatic;"Surely there is a mine for silver, and a place where gold is refined. Iron is taken from the earth, and copper is smelted from ore."Job 28:1,2Lincoln, Miller, Victor & ISV BibleDanny
Reply:You suck!!! I order one the other week and you got yours first.
Reply:Somebody needs to light a fire under your vendor! City of L.A. Structural; Manual & Semi-Automatic;"Surely there is a mine for silver, and a place where gold is refined. Iron is taken from the earth, and copper is smelted from ore."Job 28:1,2Lincoln, Miller, Victor & ISV BibleDanny
Reply:Post a pic of the equipment too.Miller Syncrowave 200Hobart Handler 140Thermal Dynamics Cutmaster 38E-Z Tube BenderPlasma Cam DHC2
Reply:not very loud?i dont know, 425 amps with 120 psi and 1/4" and larger carbons is loud enough for meonce you learn how to manipulate it in different ways you will never pick up a grinder to take another weld out again.
Reply:I have probably done more air-arcing than most of you COMBINED. So, i can say that it does NOT have to be real loud. A steady push ,while scarfing clean is not too loud. Even with a 5/8" carbon and 1000 amps . I even scarfed with an ancient Lincoln double ended generator  1200 amps. It had 2       -600 amp generators , one at each end , with the motor in the middle.[SIZE="5"Yardbird"
Reply:Originally Posted by QuciferPost a pic of the equipment too.
Reply:I have had mine for many years and use it all the time.  Electrodes are cheap.  I bought a plasma last year that will gouge, but I still prefer the arcair.  I had to replace the radius rod mount on my daughters 93 F150.  3 hot rivets and one bolt on the frame.  I burned the bolt out of the nut with the nut still intact.  If I can find the nut in my shop, I will take a pic.  I used 180 amps and a 1/8" electrode.  I use that thing all the time.David Real world weldin.  When I grow up I want to be a tig weldor.
Reply:I will answer to the noise: Set up 2-1000 amp Westinghouse machines in series and gougged with a 1" carbon, at a foundry and there was plenty of noise.  JohnSMAW,GMAW,FCAW,GTAW,SAW,PAC/PAW/OFCand Shielding Gases.  There all here. :
Reply:Once drew the job of washing out and rewelding a bunch of welded-in bearing mounts in the main gearbox of a Goodman Mining Machine used in a potash mine. I was using a 400 amp Lincoln and 175# of air. The gear box was almost 14' long so I had to crawl in and lay on my side. This was before hearing protection was even thought about. The safety department had to replace a lot of boxes of cotton in first aid kits. I was getting the cotton to plug my ears so I could stay in the gearbox with all that racket.
Reply:Originally Posted by OldtimerOnce drew the job of washing out and rewelding a bunch of welded-in bearing mounts in the main gearbox of a Goodman Mining Machine used in a potash mine. I was using a 400 amp Lincoln and 175# of air. The gear box was almost 14' long so I had to crawl in and lay on my side. This was before hearing protection was even thought about. The safety department had to replace a lot of boxes of cotton in first aid kits. I was getting the cotton to plug my ears so I could stay in the gearbox with all that racket.
Reply:Did you see this?http://weldingweb.com/vbb/showthread.php?t=21288I use that thing all the time.DavidReal world weldin.  When I grow up I want to be a tig weldor.
GMT+8, 2025-12-29 09:22 , Processed in 0.099915 second(s), 18 queries .
