Miller Spectrum 625 Plasma Cutter with Torch - $1400 (LA,CA)
发表于 2021-8-31 22:50:44 | 显示全部楼层 |阅读模式
Miller Spectrum 625 Plasma Cutter with Torch - $1400I need to pay off some VISA debt!I bought it and used it a few times on my project. It has very little time on it and has sat most of the time. It is virtually brand new!! Still has many years left in warrenty!!!here are the specs,A portable plasma arc cutter that can produce a 5/8 inch quality cut, the Spectrum 625 has loads of features that make your cutting needs a breeze. The Spectrum's ICE-40C torch is ergonomically designed to increase comfort, and the safety trigger prevents accidental starts. Pilot Arc Controller improves tip life and maintains uninterrupted cutting.Features:* Compatible with engine-driven welders capable of cutting 3/8 to 5/8 in mild steel when powered by a Miller engine-driven welder with a 240 V generator power outlet of 8 kW or more.* Power Factor Correction (PFC) circuitry draws up to 30% less amperage for the same cutting range as compared to the competition. PFC expands operators work area via extension cord, while minimizing nuisance circuit breaker trips caused by voltage drops.* Starts without high-frequency so it will not interfere with or damage controls or computers.* LED indicators for pressure, power, cup and temperature allow faster trouble-shooting, eliminating unnecessary downtime.* Consumables storage compartment provides convenient access to consumables and parts.* LVC™ Line Voltage Compensation - Keeps output of the power source constant regardless of fluctuation in input power ± 10%.* Wind Tunnel Technology™ - Internal air flow that protects electrical components and PC boards from dirt, dust, debris... greatly improving reliability.* Fan-On-Demand™ - Internal power source cooling system that only works when needed, keeping internal components cleaner.* Blow Back Torch Design - The plasma arc is created by pulling an electrical arc between an electrode and tip. This process eliminates high frequency by forcing an electrical arc between the two pieces.* Pilot Arc Switch - The expanded metal mode allows operator to cut grates, chain link fence, and other perforated metals without retriggering the gun.* Post Flow Cooling Circuit - Protection to extend the life of consumables and the welding torch is enhanced by our post flow circuit that provides shielding gas after you release the trigger.Comes Complete With:* ICE-40C hand-held torch with 50 ft (15.2 m) cable.* Heavy-duty work clamp with 25 ft (7.6 m) or 50 ft. (15.2 m) cable.# 12 ft (3.7 m) industrial power cord and plug.FULL SPECShttp://www.millerwelds.com/products/.../spectrum_625/RETAIL PRICE IS $2,095on ebay they go for $1800 plus shipping (heavy=big $$)$1400 o.b.o is a BARGAIN!I'm open to shipping but would rather go local........ Located in Los Angeles,CA email me at m3pedro at hotmail dot com
Reply:Very nice unit. It only weighs 60lbs. so it shouldn't be too much to ship. I'm on the border to laying down the money for a Spectrum 375. Let me know if your flexible. Thanks.John -  fabricator extraordinaire, car nut!-  bleeding Miller blue! http://www.weldfabzone.com
Reply:sure email me an offer , I'll ship I guessm3pedro at hotmail dot com
Reply:Sent an e-mail, thanks!John -  fabricator extraordinaire, car nut!-  bleeding Miller blue! http://www.weldfabzone.com
GMT+8, 2025-12-29 09:20 , Processed in 0.138357 second(s), 18 queries .
