Hydraulic tank repair
发表于 2021-8-31 22:50:34 | 显示全部楼层 |阅读模式
No before pics but...The filter/housing was hanging from the threadolet and the welds tore.After thoroughly cleaning the inside and out, I turned the threadolet up and filled it up with water.Brushed the paint off and made 2 passes with 6010, the 3 passes with 7018.Then built the bracket to give the housing support.The bracket is 1/4 x 5 flat bar, 10 inches long w/ 3/8x 1.5 flat bar. All 7018
Reply:Is a threadolet the same as a bung?
Reply:I used to drive a '66 Threadolet Impala!
Reply:http://www.bonneyforge.com/products....ubpg=thredolet
Reply:Wouldn't one pass around the threadolet been enough?Or is it because of the tear, you welded around it numerous times?
GMT+8, 2025-12-29 07:19 , Processed in 0.141356 second(s), 18 queries .
