stick rods for mild steel
发表于 2021-8-31 22:50:27 | 显示全部楼层 |阅读模式
what is a good brand of rods for mild steel? I have some Lincoln fleetweld 5p+ e6010 1/8 ". I got these rods at work. I'm a xray tech on natural gas pipelines. I tried these rods here at the farm and they are hard to get started. they seem to stick to easy. if they do stick and I don't get it broke free they will glow orange. so I turn the heat down and it doesn't help. what I'm I doing wrong? I have a miller bobcat 250 nt. I weld in all postions. I have no trouble running a 7018. I fact I like welding with the 7018 the best right now. but I want to get the 6010 down better.
Reply:What amperage you running?You should be around 90 amps for 1/8" 6010.Just a couple welders, big hammers, grinders, and torches.Work will free you.Men in dirty jeans built this country, while men in clean suits have destroyed it. Trump/Carson 2016-2024
Reply:If rods stick, usually the answer is to turn the amps UP, not down. Also 6010 is a DC rod and won't run at all well on AC. More info would help us help you..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:I find that a lot of the things I weld in a hurry on the farm are just too dirty to start with. I've got a couple die grinders, one with a cutoff disc and one with a small wire wheel that I use to get into tight spots. As DSW suggests, I would move the amps up, not down, when it's sticking. I'm no pro, but I've used a lot of different brands of rods and really haven't noticed a lot of difference as long as you are using the same metal content until it comes to hard surfacing. I still haven't tried the 7018's because of the storage issues, but I have good luck with 6013's and the ever despised 7014's on my AC machines.250 amp Miller DialArc AC/DC StickF-225 amp Forney AC Stick230 amp Sears AC StickLincoln 180C MIGVictor Medalist 350 O/ACut 50 PlasmaLes
GMT+8, 2025-12-29 07:19 , Processed in 0.074739 second(s), 18 queries .
