I have a new yellowish tan welding blanket that comes folded flat like a tarp(but significantly thicker). I'd like to start using it but it's really stiff and would be hard to get to conform or to wrap a preheated cast aluminum piece I'd like to start welding on. Any ideas on softening it some without losing too much of it's fire retardant abilities?Thanks,T
Reply:Any ideas?
Reply:Some are made for higher temperatures like oxy/acet cutting, whilst the lower temperature range ones are made for general weld spatter, make sure you have the correct one for the job your doing, There are different makes and finishes out there, try looking at others
Reply:They get softer with use. That's all I know.
Reply:I hate the things, made out of glass. Get's everywhere. I prefer nomex.Regards,RobGreat Basin WeldingInstagramBlue weldersRed weldersMy luscious Table DIY TIG Torch cooler
Reply:Put them all in a big pile, strip down to your shorts, and roll around in them for a while, that should soften 'em up!
Reply:OMG. Itchies for life!Regards,RobGreat Basin WeldingInstagramBlue weldersRed weldersMy luscious Table DIY TIG Torch cooler
Reply:Roll it up and beat it against a post, stump, truck bumper or some such like.
Reply:Originally Posted by AdvanPut them all in a big pile, strip down to your shorts, and roll around in them for a while, that should soften 'em up!
Reply:Take it to a Laundromat and run it in a drier for a half hour. MikeOl' Stonebreaker "Experience is the name everyone gives to their mistakes"Hobart G-213 portableMiller 175 migMiller thunderbolt ac/dc stick Victor O/A setupMakita chop saw
Reply:Originally Posted by OldendumHad a summer construction job as a kid where I had to rip off chunks of fiberglass insulation and stuff it around pipes as a fire stop. It was a miserable week or two.
Reply:If you lived here you would just hang it up outside when the wind was blowing 40+. Would be softened up in no time.
Reply:Downy? |
