How to get narrower beads
发表于 2021-8-31 22:50:24 | 显示全部楼层 |阅读模式
I'm trying to figure out how to get more narrow beads. If I do a smaller weave, they build up too much. Any ideas would be greatly appreciated.  This is my vertical up MIG.  18V 225 WFS. Attached Images
Reply:What have you done with your settings to affect a change?More heat and move faster.Regards,RobGreat Basin WeldingInstagramBlue weldersRed weldersMy luscious Table DIY TIG Torch cooler
Reply:Try one of Jody's videos - really good arc shots and easy to understand.http://welding-tv.com/2014/10/21/mig...basics-part-7/Dave J.Beware of false knowledge; it is more dangerous than ignorance. ~George Bernard Shaw~ Syncro 350Invertec v250-sThermal Arc 161 and 300MM210DialarcTried being normal once, didn't take....I think it was a Tuesday.
Reply:Settings look close to what we use on 1/8" with 92/8 and .035 solid wire. Knowing all your info would help.One thing I see is your motions could be tightened up. When you move up a large distance with each motion, you have to move slower so the material can build up to fill in between motions. If you keep your vertical travel small with each motion, you don't need to deposit as much material with each pass, thus you can make your beads smaller.The other issue I usually see with new guys learning vertical is that they haven't yet learned to read the puddle. This is the key to vertical and overhead. You can get by doing "timing patterns" on flat and horizontal, but that almost never works on vertical. To show this I do really massive weaves, I want the student to be able to carefully watch the puddle chase the arc and watch me pause for the puddle to catch up to the arc. When they say they can see this, I do the run again, but 1/2 as wide. If they say they can still see this, I'll go smaller again. until I'm at my "normal" size. At that point I'm often just doing a tiny wiggle from side to side and my movement up is probably less than a 1/32" with each motion. At this rate most students can't see me hesitate and "wait" for the puddle to catch up. In reality I almost don't have to stop because the puddle is so close behind me..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:Check this out too. http://www.millerwelds.com/resources...tips/MIG_tips/
Reply:Thanks y'all.
Reply:Well that's an easy one.. Just use smaller wire!! Lol but for real.... Dsw hit the nail on the head, small fast motions and a sharp eye on the puddle will have you laying weaves like a razors edge in no time!!Real welders know how to penetrate!(Equipment)Whatever can be used to beat my opponent into submission!
GMT+8, 2025-12-29 07:19 , Processed in 0.101949 second(s), 18 queries .
