Dry cut saw in Chop saw
发表于 2021-8-31 22:50:23 | 显示全部楼层 |阅读模式
I have a dewalt chop saw and i was wondering if i bought a dry cut saw blade if it would work well with the chop saw and give me better cuts cause ive had enough of the spark and crappy cuts im getting with these blades.ThanksJohn
Reply:The basic answer is no. The RPM on the chopsaw is way to fast for all the drycut carbide blades I have seen. At best you will destroy the blade, at worst you could get seriously hurt. Sorry I wish it would work myself. The only thing is to get the correct saw for those blades.
Reply:http://www.bulletindustries.com/carb...etal%20blades/These have been getting good reviews and are designed to use in Chop Saws and Regular Circular sawsEd Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
Reply:Thanks, Broccoli1 the 14" one looks like it would work on a std. chop saw.
Reply:Originally Posted by Broccoli1http://www.bulletindustries.com/carb...etal%20blades/These have been getting good reviews and are designed to use in Chop Saws and Regular Circular saws
Reply:Thanks for the post TSOR. I was interested until I read your results with them. I'll stick with abrasive blades for now.
Reply:I have a Milwaukee 14" dry cut chop saw with the carbide blade. I found it new on Ebay for $359.00 from a certified Milwaukee dealer. Locally they are over $500.00. You can also get one from acompany called Rage. I have one of there 7.5" metal cutting saws, works great. I wouldn't try a carbide blade in a chop saw designed for an abraisive blade. Could be bad.
Reply:damn i was hopin it would work, o well looks like ill be saving up for the dry cut saw, i was lookin at the evolution/rage saw anyways
GMT+8, 2025-12-29 07:20 , Processed in 0.109564 second(s), 18 queries .
