Needed Victor Torch Tips
发表于 2021-8-31 22:50:01 | 显示全部楼层 |阅读模式
I have a Victor  model #550-100   tip  size 00-5-100My local AirGas salesman said that this tip was now obsolete.Torch is still in very good shape and works just fine. My question is does anyone know where I may be able to locate (buy) some of this size tip. Thanks in advance for your help.Allen (Sparkey1961)
Reply:Is your cut attachment a CA 1250? If so I think you may be in luck. Check out www.gossonline.com ,from the home page scroll down to the bottom, on the left hand side of the screen, you'll see a heading that says "Cutting-Welding Replacement Tips" click on Victor, and scroll all the way to the bottom of the page, the second to the last tip is a Goss Style 2320 that fits a Victor CA1250 Cut attachment, the only question I have is the tips listed have a -101 at the end of the part number, where you listed a -100. If the -101 is your tip, my supplier has them in stock in California. They run $11.85 each, plus a few bucks freight. If these are the tips you need, and your Airgas guy can't  help you, PM me and I'll take care of it for you. I typically only sell genuine brand cutting tips, but go to aftermarket companies like Goss when the original torch manufacturer discontinues a tip.
GMT+8, 2025-12-29 11:02 , Processed in 0.145423 second(s), 18 queries .
