1953 Shorthood SA 200 Lincoln.
发表于 2021-8-31 22:50:00 | 显示全部楼层 |阅读模式
North central Louisiana.35 miles east of Shreveport Louisiana in Dubberly.1953 SA 200 Amp Lincoln.New Cast Iorn Gray Paint Job.Clean hood-Face-Radiator Guard.Face is painted Red.Not the original engine that was a F-162 Now it has a F-163.Electric Start.Round Generator-Amature 100% all copper windings.New Lincoln Arc Welder Decals on both sides of hood.Miller Killer Decal on the Red Face.Leads go with machine about 150 feet.Engine work as follows with less than 40 hours of running.Block Boiled and cleaned in chemical acid vat.Block deck surfaced.New valve seats and valves with a 3 angle valve job.Head surfaced.All new freeze plugs.Rebuilt 6" Rods with brass bushings in the small end and resized within 0.1 thousandths on big end.New 20 over forged flat top pistons with new floating wrist pins.Newly turned and polished crank-shaft turned 20 on the main journals and 20 on the rod journals.New cam bearings all bearings are Clevite 77.New cam and lifters.New Cam and crank gears.New water pump.Rebuilt Magneto.New gas settlement bowl and assembly and gas line.New points.New plug wires.Original radiator but no leaks.This machine runs like a champ as it welds.Original engine F-162 to go with it needs rebuilding.Extra F-162 engine so you get two extra engines.New reostat and adjustment handle.New exhaust pipe from intake manifold through the hood.New choke cable.Extra Carb.Extra short hood machine for parts hood-frame-face-gas tank exct.DC Current with DC Plug-In outlet to run an extention cord and all DC Grinders ect.This machine is a Pipeliner Classic dont see them around much.Can be used for all your welding needs pertaining to stick welding and will last a man for years to come.They dont make em this tough anymore.E-Mail steve @ [email protected] or call.318-377-1088 home318-382-3029 cell.Call and make offer.Thanks Steven.Last edited by classiclincoln; 03-31-2007 at 07:55 AM.Good welding is between the shoulder and the holder.I also like the decal logo that says: MILLER                                                    KILLER
GMT+8, 2025-12-29 09:18 , Processed in 0.147692 second(s), 18 queries .
