查看: 2|回复: 0
tube notcher
发表于 2021-8-31 22:49:58 | 显示全部楼层 |阅读模式
One of the best tools that I purchased to date,  notches tube perfect everytime.  Well worth the money if you are in the market.  Balieghs tn-250, this thing is heavy and beefy brothers. Attached Images
Reply:Awesome looking. I did some research on this and it got great reviews. I was thinking of projects just so I could order one. Did you use it on schedule 40 pipe ? That's what I would be using it for.
Reply:I have one of them. Great tool. I picked mine up about 6 months ago along with hydraulic upgrade kit for my bender. Attached ImagesScooterLincoln Weld-pak 155 - .030 Solid wire & 75/25 gas mixMiller Thunderbolt 225Hypertherm PM 85Thermal Dynamics cutmaster 38Gas ax with rose bud attachment
Reply:Nice beefy looking rig!  I purchased my USA made 'OL Joint Jigger Model RTN 100 a few years ago for about $150. The thing I really love about my Jigger is it's light weight and portability...allowing me to take it to the work rather than bring the work to it. I just slide 'er on the pipe in any position...tighten the clamp...and hit the trigger. Having a very small garage shop, it's been one of my favorite tools. I spray on Jancy water based coolant about every 10 seconds while cutting and easily get a hundred cuts from a Lenox $15 holesaw. In the photo you'll notice a tab I welded on to easily clamp the jigger in my vise if I so desire when notching small parts. Cheap...cheap...cheap!   Attached ImagesPOVERTY...is the Mother of InventionMillermatic 211Millermatic 140Miller Thunderbolt XLArcOne 100STS inverter w/TIGThermal Dynamics 38XL Victor Oxy/AcetyleneJancy Slugger Holemaker IIJet 5x6 BandsawNever enough time & sleep.
Reply:Its what I'll be getting when the time comes.AaronJet 17.5" Drill Press1942 South Bend 16x84 Lathe1980s Miller 320A / BP --- 2013 Power Mig 2562012 Jet 7x12 Horizontal BandsawVictor O/A Setup
Reply:Originally Posted by SMC WeldcraftNice beefy looking rig!  I purchased my USA made 'OL Joint Jigger Model RTN 100 a few years ago for about $150. The thing I really love about my Jigger is it's light weight and portability...allowing me to take it to the work rather than bring the work to it. I just slide 'er on the pipe in any position...tighten the clamp...and hit the trigger. Having a very small garage shop, it's been one of my favorite tools. I spray on Jancy water based coolant about every 10 seconds while cutting and easily get a hundred cuts from a Lenox $15 holesaw. In the photo you'll notice a tab I welded on to easily clamp the jigger in my vise if I so desire when notching small parts. Cheap...cheap...cheap!
Reply:I've got the JD2 Notchmaster. I really like it. Works well for me (occasional user).
Reply:I mostly have used a JD2 notcher. The offset adjustment on that thing looks cooler than the other side of a pillow though. I can think of some times when it would have come in handy.I had the unfortunate experience of using an 'Ol Joint Jigger (a well used one I might add) ONCE. Between it and the chinese no-balls drill I had to use, it almost took a flight across the shop. If it had been MY shop it would have. I promptly went back to doing it by hand on a belt sander.
Reply:I have that same Baileigh notcher.  Worth every penny and then some.  Haven't found a joint that couldn't be done, even step angles.  Heck, I've used it to open up the I.D. of some tube before.  Great tool if your in the market for one
GMT+8, 2025-12-29 09:21 , Processed in 0.094486 second(s), 18 queries .
