Tree and Flowers
发表于 2021-8-31 22:49:57 | 显示全部楼层 |阅读模式
Been collecting drops and small clean steel,aluminum,ect.. for well ya never know when it may come in handy sometime or to make a small project. This is made from steel punch drops.Tig welded with 1/16 tung and 045 filler. Not painted yet tomarrows project. Hope everyone enjoys Iam trying to keep up with Fexal and his cool projects lol I like drag racing to!! Attached ImagesLast edited by power; 07-06-2013 at 08:32 PM.Miller 250DX HTP 221 DV AC/DCHenrob O-A Miller 180 MigMiller 150 Inverter   Hobart 10,000 Welder-Generator   Have a good day!!!
Reply:What kind of flowers? Metalic Daisies?
Reply:Originally Posted by InsanerideWhat kind of flowers? Metalic Daisies?
Reply:Originally Posted by 7A749Metallic Dasies sounds like an all girl heavy metal glam band from the '80's! Cool stuff Dale.
Reply:I like those flowers............I can just imagine what the band would look like...... hot chicks with tattoos and dudes as groupies......Precision TIG 185 and MP 210Bobcat 225NTCutmaster 42O/A tanks.... 2 Argon tanks...... 2 C25 TanksFacebook...... F2 Metal WorksETSY....... https://www.etsy.com/shop/F2MetalWorksF2MetalWorks.com....... http://www.f2metalworks.com/
Reply:Originally Posted by FexalI like those flowers............I can just imagine what the band would look like...... hot chicks with tattoos and dudes as groupies......
Reply:powerYou're on to something; consider a little separationbetween elements and fusion only on one side.The first photo is the most interesting  -  develop it.Opus
Reply:That is really cool. It looks like a complicated job but you nailed it.PlasmaCam CNC cutterLathe and Band SawClamps
Reply:Made a few of these for friends some painted some not. Attached ImagesMiller 250DX HTP 221 DV AC/DCHenrob O-A Miller 180 MigMiller 150 Inverter   Hobart 10,000 Welder-Generator   Have a good day!!!
Reply:Not to be critical, but have you thought about bending the petals of the flowers out a bit from the center? Most all flowers are not on a perfectly flat plain with the center part. This would giive a little more depth of view, and be a bit more natural looking. Just heat the weld enough to fold them outward some. Just thought it might be something you might want to consider, otherwise they look good. Maybe find a way to add a couple of leaves to each stem too.  I wouldn't doubt Zapster has something to say about the trees.
Reply:How did you get the dimples in the pedals?I really like that look......Precision TIG 185 and MP 210Bobcat 225NTCutmaster 42O/A tanks.... 2 Argon tanks...... 2 C25 TanksFacebook...... F2 Metal WorksETSY....... https://www.etsy.com/shop/F2MetalWorksF2MetalWorks.com....... http://www.f2metalworks.com/
Reply:Originally Posted by BistineauNot to be critical, but have you thought about bending the petals of the flowers out a bit from the center? Most all flowers are not on a perfectly flat plain with the center part. This would giive a little more depth of view, and be a bit more natural looking. Just heat the weld enough to fold them outward some. Just thought it might be something you might want to consider, otherwise they look good. Maybe find a way to add a couple of leaves to each stem too.  I wouldn't doubt Zapster has something to say about the trees.
Reply:Originally Posted by FexalHow did you get the dimples in the pedals?I really like that look......
Reply:Cool stuff, great use of scraps. Like more the black ones. Way to go!
Reply:Originally Posted by powerThanx, I agree with bending the pedals and like the idea of leaves!
GMT+8, 2025-12-29 11:03 , Processed in 0.072984 second(s), 18 queries .
